#21 |
Formula 5000 Champion
![]() Drives: 2012 Black GTI (DSG) Join Date: Jun 2011
Emergency Brake Flashing via Brake Lights/Turn Signals Active
How-To WARNING: I will not be held liable if anything occurs when attempting to change anything in the VCDS software. These instructions are created to the best of my knowledge and are as accurate as I can make them. Please be careful before you save your settings and always run Auto-Scan before any changes are attempted. ![]() Load up VCDS, click on the Select button under Select Control Module ![]() Click on the 09-Cent. Elect. button ![]() Click on the Coding - 07 button ![]() Click on the Long Code Helper button ![]() Go to Byte 16 and check mark Bit 1 - Emergency Brake Flashing via Brake Lights Active Also, check mark Bit 2 - Emergency Brake Flashing via Turn Signals Active if preferred as well
2012 DEEP BLACK PEARL GTI DSG | APR Stage 1 | DriverGear Springs zVp's Car Journal Last edited by zVp; 09-08-2012 at 09:12 PM. |
#22 |
Automatic Rear Window Wiping with Reverse Gear Disabled
How-To WARNING: I will not be held liable if anything occurs when attempting to change anything in the VCDS software. These instructions are created to the best of my knowledge and are as accurate as I can make them. Please be careful before you save your settings and always run Auto-Scan before any changes are attempted. ![]() Load up VCDS, click on the Select button under Select Control Module ![]() Click on the 09-Cent. Elect. button ![]() Click on the Coding - 07 button ![]() Click on the Long Code Helper button ![]() Go to Byte 21 and uncheck mark Bit 6 - Automatic Rear Window Wiping with Reverse Gear Active to deactivate this option
2012 DEEP BLACK PEARL GTI DSG | APR Stage 1 | DriverGear Springs zVp's Car Journal Last edited by zVp; 09-08-2012 at 09:06 PM. |
#23 |
DRL MFA Menu
How-To WARNING: I will not be held liable if anything occurs when attempting to change anything in the VCDS software. These instructions are created to the best of my knowledge and are as accurate as I can make them. Please be careful before you save your settings and always run Auto-Scan before any changes are attempted. WARNING: Please follow your state's, province's and/or country's regulations on DRLs. I do not condone disabling DRLs if the law states you must have them at all times on your vehicle. ![]() Load up VCDS, click on the Select button under Select Control Module ![]() Click on the 09-Cent. Elect. button ![]() Click on the Coding - 07 button ![]() Click on the Long Code Helper button ![]() Go to Byte 15 and check Bit 7 - Daytime Running Lights (DRLs) Adaptation active (MFA+) ![]() You can now turn on/off your DRLs on the fly with the menu in the MFA. It should be under Lights/Vision sub-menu. Checkmarked means your DRLs are active; unmarked means your DRLs are inactive. Please note, you cannot change this while the car is moving - please do not attempt to turn on/off DRLs while operating a moving vehicle.
2012 DEEP BLACK PEARL GTI DSG | APR Stage 1 | DriverGear Springs zVp's Car Journal Last edited by zVp; 09-07-2012 at 07:38 PM. |
#24 |
Horn Confirmation when Locking MFA Menu
Thanks to veedoubleme at http://www.golfmk6.com/forums/showpo...16&postcount=9 How-To WARNING: I will not be held liable if anything occurs when attempting to change anything in the VCDS software. These instructions are created to the best of my knowledge and are as accurate as I can make them. Please be careful before you save your settings and always run Auto-Scan before any changes are attempted. ![]() Load up VCDS, click on the Select button under Select Control Module ![]() Click on the 09-Cent. Elect. button ![]() Click on the Coding - 07 button ![]() Click on the Long Code Helper button ![]() Go to Byte 5 and uncheck Bit 2 - Horn Confirmation Adaptation Blocked (Adaptation Channel 010/011 & MFA+/FIS) ![]() You can now turn on/off your horn confirmation when locking on the fly with the menu in the MFA. It should be under the Convenience sub-menu. Checkmarked means your horn will beep when locking the doors; unmarked means your horn will not beep when locking the doors.
2012 DEEP BLACK PEARL GTI DSG | APR Stage 1 | DriverGear Springs zVp's Car Journal Last edited by zVp; 09-08-2012 at 08:45 PM. |
#25 |
Fog Lights active with High Beams active
How-To WARNING: I will not be held liable if anything occurs when attempting to change anything in the VCDS software. These instructions are created to the best of my knowledge and are as accurate as I can make them. Please be careful before you save your settings and always run Auto-Scan before any changes are attempted. WARNING: Please follow your state's, province's and/or country's regulations on the maximum number of lights can be active at one time. ![]() Load up VCDS, click on the Select button under Select Control Module ![]() Click on the 09-Cent. Elect. button ![]() Click on the Coding - 07 button ![]() Click on the Long Code Helper button ![]() Go to Byte 14 and uncheck Bit 2 - Fog Lights inactive with High Beams active Now you can use your high beams and fogs at the same time.
2012 DEEP BLACK PEARL GTI DSG | APR Stage 1 | DriverGear Springs zVp's Car Journal Last edited by zVp; 09-08-2012 at 09:14 PM. |
#26 |
Comfort Closing/Opening via Remote Control
How-To WARNING: I will not be held liable if anything occurs when attempting to change anything in the VCDS software. These instructions are created to the best of my knowledge and are as accurate as I can make them. Please be careful before you save your settings and always run Auto-Scan before any changes are attempted. ![]() Load up VCDS, click on the Select button under Select Control Module ![]() Click on the 09-Cent. Elect. button ![]() Click on the Coding - 07 button ![]() Click on the Long Code Helper button ![]() Go to Byte 3 and check Bit 5 - Comfort Operation via Remote Control Active Checking Bit 0 - Comfort Opening for Sliding Roof Active will also open the moonroof while opening the windows via the remote fob. I did not activate this setting. NOTE: This may not work. Apparently some update from the dealer that deals with the fan running after the car is shut off affects this coding. See http://forums.vwvortex.com/showthrea...control-on-Mk6 for more information. Press and HOLD the lock button on your fob to close all the windows. HOLD until all windows are closed or until preferred height. Press and HOLD the unlock button on your fob to open all the windows. HOLD until all windows are open or until preferred height.
2012 DEEP BLACK PEARL GTI DSG | APR Stage 1 | DriverGear Springs zVp's Car Journal Last edited by zVp; 09-07-2012 at 07:45 PM. |
#27 |
Comfort Turning Signal
How-To WARNING: I will not be held liable if anything occurs when attempting to change anything in the VCDS software. These instructions are created to the best of my knowledge and are as accurate as I can make them. Please be careful before you save your settings and always run Auto-Scan before any changes are attempted. ![]() Load up VCDS, click on the Select button under Select Control Module ![]() Click on the 09-Cent. Elect. button ![]() Click on the Adaptation - 10 button ![]() On the drop-down menu, select Comfort Turn Signals (Cycles) ![]() Change to your preferred number of cycles/blinks (3 is default) using the Up and Dn buttons Save your changes. Depending on the model and/or year of your car, this will not work right away. Go to your MFA menus, enter the LIGHTS/VISION menu and restore settings to factory. Attempt to use the comfort turn signal.
2012 DEEP BLACK PEARL GTI DSG | APR Stage 1 | DriverGear Springs zVp's Car Journal Last edited by zVp; 09-08-2012 at 09:00 PM. |
#28 |
Steering Wheel Push-To-Talk Button
If you have a newer steering wheel with a Push-To-Talk (PTT) button on the bottom left of your steering wheel, you can change it to act as a mute button. How-To WARNING: I will not be held liable if anything occurs when attempting to change anything in the VCDS software. These instructions are created to the best of my knowledge and are as accurate as I can make them. Please be careful before you save your settings and always run Auto-Scan before any changes are attempted. ![]() Load up VCDS, click on the Select button under Select Control Module ![]() Click on the 19-Steering Wheel button ![]() Click on the Coding - 07 button ![]() Click on the Long Coding Helper button ![]() Go to Byte 1 and uncheck Bit 3 - Multi-Function-Steering-Wheel (MFSW) with Push-To-Talk (PPT) Button installed The Push-To-Talk (PPT) button will now act as a mute button.
2012 DEEP BLACK PEARL GTI DSG | APR Stage 1 | DriverGear Springs zVp's Car Journal Last edited by zVp; 09-09-2012 at 10:04 AM. |
#29 | |
FIA GT Champion
![]() Drives: 2010 GTI Join Date: Jul 2010
Sounds good though... Cant wait for spring!
CSG GTI - | DSG | APR S1 | APR Intake | LED Tails | GTA Detailing & Paint Correction |
#30 |
Rally Car Champion
![]() Drives: 5dr MKVI GTI Join Date: Nov 2009
wow thank you work you put into making the helpful vagcom walkthroughs
#31 |
Thank you, I just hope it helps people
2012 DEEP BLACK PEARL GTI DSG | APR Stage 1 | DriverGear Springs zVp's Car Journal |
#32 |
Formula 3000 Driver
![]() Drives: 2011 VW GTI 4dr Autobahn DSG Join Date: Jun 2011
Awesome thread! All things vagcom in one place with easy instructions! This helps me a ton.
APR stage 2+ tune, Neuspeed P-Flow intake with AEM Dryflow filter, Raceland DP, lots of Vagcom tweaks, ECS smoked side markers, Whiteline 24mm rear sway bar "hard", Hankook Ventus V2 tires, AWE tuning CBE |
#33 |
Warning Triangle & First Aid Kit
Thanks to Tim_S at http://forums.vwvortex.com/showthrea...rning-Triangle Parts Required N 105 412 01 - White Plug N 906 513 04 - Black Screw 1K6 860 266 D 9B9 - Strap/Bracket 000 093 057 - CORRECT Warning Triangle (Do not use 1Y0 093 055 as it is too narrow to fit); You can also use 8D9 860 251B (EOS Warning Triangle) as a replacement. They are both the same size, I believe. Now, its up to you which first aid kit you want to use. 000 093 114 - Blue First Aid Kit (Correct one for Gofl/GTI) ![]() 3C0 093 108 - Red First Aid Kit (Passat kit for rear seat armrest) They will both fit; I got the red one myself since I prefer the colour. Instructions Open your trunk and look on the left side. There will be a black plug; you will have to get this out. IMPORTANT: Pull back your carpet and insert the white plug into the hole in the side of the trunk. Put back the carpet. If you put the white plug over the carpet, it will move around and not be sturdy. Putting it behind the carpet solves the problem. Screw the bracket into the white plug in the correct orientation. Put your warning triangle in and then strap in the first aid kit. WILL POST PICTURES LATER
2012 DEEP BLACK PEARL GTI DSG | APR Stage 1 | DriverGear Springs zVp's Car Journal Last edited by zVp; 02-16-2012 at 07:16 PM. |
#34 |
Driver Seat Heating Memory Retention
How-To WARNING: I will not be held liable if anything occurs when attempting to change anything in the VCDS software. These instructions are created to the best of my knowledge and are as accurate as I can make them. Please be careful before you save your settings and always run Auto-Scan before any changes are attempted. ![]() Load up VCDS, click on the Select button under Select Control Module ![]() Click on the 08-Auto HVAC button ![]() Click on the Adaptation - 10 button ![]() This window will pop up - expand the drop-down menu. ![]() In the drop-down menu, select Retention of driver's seat heater level ![]() Select On and save your settings. When turning back your car after leaving your heated seat on, it will retain that setting.
2012 DEEP BLACK PEARL GTI DSG | APR Stage 1 | DriverGear Springs zVp's Car Journal Last edited by zVp; 09-08-2012 at 09:05 PM. |
#35 |
Just messing with my dad's video function of his Sony NEX-5. Nice little mirrorless DSLR. So much easier to lug that thing around than a small Canon 400D.
#36 |
Finally finished installing the Aspherical Mirrors from the group buy http://www.golfmk6.com/forums/showthread.php?t=28838. Thanks quickit!
Used a butter knife wrapped in a microfibre cloth and pryed open the mirror. Unfortunately, the passenger side mirror cracked when I tried to get that open, but the driver side was a lot more forgiving. Used a flat-head screwdriver to slowly remove the leads for the heated mirrors and just popped back the mirrors into the housing. Pretty easy, except for the cracking mirror ![]() I didn't really pay attention before but, is it just me or is the passenger side mirror more recessed into the housing than the driver side?
#37 |
Mirror Adjust Menu in MFA
For 2011s and up. Apparently 2010s will have this menu. How-To WARNING: I will not be held liable if anything occurs when attempting to change anything in the VCDS software. These instructions are created to the best of my knowledge and are as accurate as I can make them. Please be careful before you save your settings and always run Auto-Scan before any changes are attempted. ![]() Load up VCDS, click on the Select button under Select Control Module ![]() Click on the 09-Cent. Elect. button ![]() Click on the Coding - 07 button ![]() Click on the Long Code Helper button ![]() Go to Byte 8 and check Bit 6 - Synchronized Mirror Adjustment You will now have Mirror Adjust in your Convenience sub-menu. If you continue deeper into the menus, you will see Both and Individual, referring to adjusting your side mirrors simultaneously or one at a time depending on which side mirror you select. ![]() ![]()
2012 DEEP BLACK PEARL GTI DSG | APR Stage 1 | DriverGear Springs zVp's Car Journal Last edited by zVp; 09-09-2012 at 09:58 AM. |
#38 |
Coming/Leaving Home Menu in MFA
How-To WARNING: I will not be held liable if anything occurs when attempting to change anything in the VCDS software. These instructions are created to the best of my knowledge and are as accurate as I can make them. Please be careful before you save your settings and always run Auto-Scan before any changes are attempted. ![]() Load up VCDS, click on the Select button under Select Control Module ![]() Click on the 09-Cent. Elect. button ![]() Click on the Coding - 07 button ![]() Click on the Long Code Helper button ![]() Go to Byte 12 and check Bit 2 - Coming-Home Mode (0 = Automatic / 1 = Manual) ![]() Go to Byte 17 and check Bit 5 - Coming-Home (CH) Active and Bit 6 - Leaving-Home (CH) Active You will have the Coming Home and Leaving Home menu in your MFA. If you go deeper into the menus, you can set the interval in +/- 10 sec to your preference. ![]() ![]() ![]()
2012 DEEP BLACK PEARL GTI DSG | APR Stage 1 | DriverGear Springs zVp's Car Journal Last edited by zVp; 09-08-2012 at 08:50 PM. |
#39 |
Not really pictures of the GTI or anything, but I did do some car related things today. Went to the Canadian International Autoshow!
Saw a bunch of cool cars, but it was really busy today. Not really a good day to take good pictures I got fed up of people walking in front of cars as I'm trying to get pictures of. So instead of trying to get a full shot of a car, tried to do something more "artistic" of some sort. Of course, they did pay for entrance as well so they have all the right to do what they please when they come here, but c'mon. You see a guy trying to take a photo of a car, don't just walk in front of them!Also got picked to test drive some Mercedes Benz vehicles around a little course at Ontario Place. It was a really small course, but it was a nice little experience. Unfortunately, not AMG vehicles though! E-Class - Sweet car, nice power, but ABSOLUTELY HATE the shifter. It's like a Mini-Van shifter. Smart ForTwo - Funny little car to drive around. The brakes were shot on that car though. GLK - Great little SUV. I actually really liked it. Unfortunately, I got stuck behind the shuttlebus taking some people around for a little "test" drive around the course so I couldn't really push it too hard. C-Class - What a disappointment. Slow and just... well, slow. Did not like at all. ![]() Lexus LFA ![]() Mazda Shinari Concept (SHARP LOOKING CAR) ![]() BMW Vision Connected Concept ![]() BMW Vision Connected Concept ![]() BMW Vision Connected Concept ![]() Acura NSX Concept
#40 |
Hill Hold Control (HHC)
How-To WARNING: I will not be held liable if anything occurs when attempting to change anything in the VCDS software. These instructions are created to the best of my knowledge and are as accurate as I can make them. Please be careful before you save your settings and always run Auto-Scan before any changes are attempted. ![]() Load up VCDS, click on the Select button under Select Control Module ![]() Click on the 03-ABS Brakes button ![]() Click on the Adaptation - 10 button ![]() This window will pop up - expand the drop-down menu. ![]() Click on the drop-down menu and select Hill Hold Control (HHC) ![]() Change Hill Hold Control (HHC) to your preference. NOTE: If you have disabled Hill Hold Control (HHC), you will not be able to enter these menus.
2012 DEEP BLACK PEARL GTI DSG | APR Stage 1 | DriverGear Springs zVp's Car Journal Last edited by zVp; 09-09-2012 at 03:51 PM. |
| Tags |
| zvp |
| Thread Tools | Search this Thread |
| Display Modes | |
