Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Technical Topics > Cosmetic Mods (interior & exterior modifications)
Old 03-01-2012, 09:14 AM   #21
phd-12v
phd-12v's Avatar
Drives: 2010 MK6 Gti
If you do the coding above in the original post, there should be no reason it shouldnt work, this is a US vehicle without LED tails. Halogen original equipped with standard fog lights.
Jason---2010 GTI DSG, 1989 W.E. Cabriolet
Automotive Data Solutions--Technical Support
www.idatalink.com
Encore Automotive Systems-Dir. of Technical Support
www.encoreautomotivesystems.com
phd-12v is offline   Reply With Quote
Old 03-01-2012, 09:20 AM   #22
xHeartcoreboyx
Formula 2 Champion
xHeartcoreboyx's Avatar
Drives: '10 CW 2DR GTI DSG
I have, but i have LED tails and it's a euro spec...I dont mind a bulb out, but i can't get leds to run in 0 position no matter what i try!
Sent from my iPhone with typos
| APR Stage II v1.2 | APR FMIC | Ultimate Racing DP | Carbon Speed intake | Carbonio stg2 pipe | Neuspeed TOP | Noisepipe delete | Rev 'd' DV | SPAX RSX Coilovers | 3SDM 0.01 Wheels | StopTech Pads | P3 Digital Gauge | Vagcom | Build thread |
xHeartcoreboyx is offline   Reply With Quote
Old 03-01-2012, 09:55 AM   #23
phd-12v
phd-12v's Avatar
whats weird is it only required coding as i posted, without ever changing byte 18........gotta figure out this out. anyone in Pitt wanna let me borrow their led tails for a couple days??? lol
www.idatalink.com
Old 03-02-2012, 10:21 AM   #24
phd-12v
phd-12v's Avatar
here is what it looks like with the coding for LED and FOG drl:
www.idatalink.com
Old 03-02-2012, 10:25 AM   #25
xHeartcoreboyx
Formula 2 Champion
Seriously, i can't think of anything i could have missed...
Old 03-02-2012, 10:27 AM   #26
phd-12v
phd-12v's Avatar
what is byte 18 coded at for you???
www.idatalink.com
Old 03-02-2012, 10:32 AM   #27
xHeartcoreboyx
Formula 2 Champion
I have set it to 04 (ROW GTI) and also tried to set it to 00..it throws a code in North America choice, since mine isn't.
Old 03-02-2012, 01:10 PM   #28
phd-12v
phd-12v's Avatar
what about ROW golf?
www.idatalink.com
Old 03-03-2012, 12:59 PM   #29
ErsteGTI
Oval Champion
Drives: White 2011 GTI 4dr DSG
Can someone explain to me if there is a light configuration difference between running LEDs as DRL or from parking position using Euro Switch? I'm trying to understand what the benefit is to running LEDs as DRL.
ErsteGTI is offline   Reply With Quote
Old 03-03-2012, 01:01 PM   #30
Nimche
Drives: 2012 5DR-GTI
Benefit that I see is that you could leave the switch at off position and LED will turn on by DRL.
5DR GTI ~ United Grey
Windows Tint ~ Euro Switch ~ Vag-com ~ Swap RCD510 to RNS510 ~ LED taillights [ED] ~ Aspherical Mirror ~ Mirror Cover Black Paint
Past & Future
Nimche is offline   Reply With Quote
Old 03-03-2012, 01:16 PM   #31
ErsteGTI
Oval Champion
Thanks Nimche. I think the auto turn-on is cool. Do you know if the tails turn on in either parking light position or when running DRL
Old 03-03-2012, 01:23 PM   #32
JasonH
Touring Car Champion
Drives: 2011 MK6 UG GTI w/ AVIC-Z130BT
Hey Jason,
Is it possible to have the LEDs on all the time (DRL & Lowbeam) without throwing a code?
Also, do the motors in these lights only move up/down or are they fully directional? I'm thinking I could rig up an accelerometer based "AFS like" system if the motors move in all directions.
Thanks!
JasonH is offline   Reply With Quote
Old 03-03-2012, 01:24 PM   #33
Nimche
I think in DRL you will see only the headlight LEDS but in parking taillights are on. I have to double check again for both. I am want the taillights be on all the time too, only way to show them off..
Past & Future
Old 03-03-2012, 11:40 PM   #34
lissav
Oval Newbie
Drives: 2012 GOLF TDI 4 Door
Is there any difference in the LED brightness between being set as DRL and parking lights? Just wondering if someone noticed anything, thanks..
lissav is offline   Reply With Quote
Old 03-03-2012, 11:50 PM   #35
snowboardgti
Oval Newbie
Drives: mk6 gti 2010
hm.. im wondering too. my leds are super dim during daytime.
snowboardgti is offline   Reply With Quote
Old 03-04-2012, 12:19 AM   #36
lissav
Oval Newbie
Same here, which is normal, but I've seen a gti on the road with the same LEDs during the day and the seemed much brighter
Old 03-04-2012, 04:47 AM   #37
rc0224
FIA GT Newbie
rc0224's Avatar
Drives: 2010 MKVI Golf 2.5L 5-Doors DBP
quick question, so if i want LED as DRL and off when the low beam is on, i'll need a trigger wire right? or can i just do the coding in the vag-com??
APR Carbino Intake | Carbon Fiber Rear Diffuser | GTI AWE Catback | Vortex Rear Spoiler | RG Front Lip | Osir Side Skirts w/ Carbon Fiber Inserts | OEM Tinted R LED Tail
H&R Street Performance Coilovers | APR 27mm RSB
Black Replica LED Headlight | Avant Garde M310 G/M (Continental DWS)
rc0224 is offline   Reply With Quote
Old 03-05-2012, 09:19 PM   #38
darth_furious
Drives: 2010 Golf Variant TDI, REVO stg1
Originally Posted by darth_furious View Post
BYTE 18 - is 20
BYTE 14 - is 09 (check bit 3)
BYTE 15 - is C4 (check bit 6, bit 7)
BYTE 24 - is E4 (check bit 7)
BYTE 27 - is 24 (check bit 2)
This worked for me! I had byte 18,15,24, and 27, but everytime the "check DRL" notice came up and it never worked. Once I set byte 14 (check bit 3) to select bixenon with shutters, it worked. However, my highbeams now don't work.
Hmmm...DRLs or Highbeams? I personally am sticking with DRLs but the choice is yours.
Got the high beams working! I had to uncheck byte 14 [bit 3] and then change byte 18 from 00 to 20. Now it works perfectly. Thanks for the help!
darth_furious is offline   Reply With Quote
Old 03-12-2012, 08:17 PM   #39
elro
Drives: 2011 Golf TDI Highline Wagon DSG
I'm having similar issues that you had before you got your results.
Are you using the stock switch or Euroswitch? I'm using the stock switch with:
DRL is set as active
Byte 14 (check bit 2,3) tried bit 3 only with same results
Byte 15 (check bit 2,6,7) bit 6,7 only with same results
Byte 24 (check bit 7)
Byte 27 (check bit 2)
Byte 18 (not changed at factory setting 00)
Results: bulb out code, error message for DRL. My LEDs are on with low beams, I have no DRLs and no low beams. It looks like the only thing that I haven't tried is the byte 18, but I'm hesitant to change that. Any help would be appreciated.
Long code:
2D380E3F902F3EC400880081600009C401000086535D8560E4 8020040040
Thank you.
Ron
elro is offline   Reply With Quote
Old 03-12-2012, 09:54 PM   #40
phd-12v
phd-12v's Avatar
Ron, great talking to you tonight. If you need anything else let me know.
edit: ELRO is working, and all is good. Just took a few minutes of walking through some vag-com settings. I am learning much more everytime as we have some variations in the CECM's
www.idatalink.com
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
