untangle
A non-VW tech & I installed the S3 FMIC and AWE TOP yesterday. With a lift and full power tools, it took about 4 hours.
I bought the S3 FMIC from Genuine for $300 delivered, and the AWE TOP from AWE for $200.
Here are some tips to make the install go faster:
Initial driving impressions:
If you are at Stage II, this mod will definitely improve the overall performance of your GTI. On my Revo-tuned car, the magnitude of the performance improvement was closer to that of the DP than the intake. I'm sure that the stock car and Stage I cars are also improved, but I have no direct experience.
Given that fuel economy will also invariably improve, I can recommend this mod without reservation.
OK, since I'm sure that I'll be asked, here's why I went S3 vice APR, Twincooler, etc.:
Incidentally, I have 5000 miles on the car and found very little oil in the IC/hoses. But I mix long and short trips and 'drive it like I own it' daily.
Some pix below.
Bob
- Two people!
- The bottom of the (gloss black) grill and the 'wings' of the bumper cover just pop out. They may seem stuck, but they pop.
- The screws to mount the A/C condenser don't work with the S3 piece. I think these are M6x16.
- I definitely recommend the MR2toVW procedure for re-using the stock hoses. Very nice. (His data is also very nice!)
- Use plac's DIY, also nice
- Whoa! Much stronger than I expected. Although untrue, it felt like another DP.
- Greater urge everywhere
- Much stronger pull through the gears
- Quicker throttle response almost everywhere
- The one flaw: When cold, if you get the car in one of those odd regimes where you are decel'ing and the turbo completely de-spools, the mods makes the pullout from this even more laggy. I could not repeat when warm.
- I do not plan to go K04 and I believe that this is right-sized for K03
- I live in a temperate climate (although our racetracks get hot in the summer)
- All things being equal, lower volume equals less lag
- I am not precluded from *adding* the Twincooler. I personally think that 'S3+Twincooler' is the best way to deploy Twincooler (for flow reasons).
- I got the FMIC *and* the TOP for $500 (and I wanted the TOP).
Some pix below.
Bob
