fatty@golfmk6.com
Just wanted to make a list of the current boost gauges that fit the mk6. I'm trying to decide on which boost gauge to get and being able to see all of them together helps. Hope this helps anyone else on the fence about boost gauges!
Option 1 : AWE Tuning boost gauge kit
Pros - matches the back light almost exactly
Cons - (not sure if this is a con or not) mounted only in the driver side vent
Price - around $190 ish
http://www.awe-tuning.com/products/vw-1/mk6-g-j-2010/gti-20t/mk6-2-0t-vent-mounted-boost-gauge-kit.html
Option 2 : P3 Digital boost gauge
Pros - Digital boost readings, sleek design, and it can do more than just read boost (0-60 timing, shift light etc). also there are lots of options to fit everyone (standard,premium, plus)
Cons - (not sure if this is a con or not) mounted only in the driver side vent. Also it will take a big chunk out of your wallet :yikes:
Price - ranges from $364 (standard) to $419 (Premium plus)
http://www.p3cars.com/mk6/
there is a youtube video too showing the different features
http://www.youtube.com/watch?v=x0tYQ1rSdj8&feature=player_embedded
Option 3 : New South Performance Boost Gauge
Pros - versatile ! it can be installed in the vent or it can be put in a pod to fit on the steering column and you can adjust the color of the lights if needed.
Cons - Wiring is a little difficult. Doesn't match the steering column very much. You would have to buy the pod separately I believe, so that might be a little something extra. According to lowerthanzimmy "it f***ing sucks", and there may be some rubbing issues
Price - around $150
http://www.namotorsports.net/detail.cfm/part_cd/NPTPB.025
Option 4 : Defi White Racers Boost Gauge
Pros - looks really nice imo it also does this really cool sweep when you turn it on. animation is on the website. Fitted on the steering column as well
Cons - blocks the MFI
Price - around $230
http://uspmotorsports.com/product_info.php?products_id=370
Option 5 : Podi MK6 Boost gauge
Pros - attached to the steering column with a pod, also not as bulky as other column boost gauges. there are 16 LEDs used to uniformly backlight the dial and 4 LEDs used to light up the needle. comes with a remote !
Cons - Just came out so not sure how it will perform. But i'm sure it'll be fine
Price - Presale (til may 16th) $249 (includes boost tap, t shirt, and free shipping) or you can pay $219 ( includes free shipping).
More info if you're interested http://golfmk6.com/forums/showthread.php?t=14199
http://golfmk6.com/forums/showthread.php?t=18696
Option 6 : Concepts in Motion
Pros - matches the back ground color of the tachometer very nicely
Cons - this is a vent boost gauge that is installed in the center vents above the headunit rather than the driver side vent
Price - The vent pod package is $170
http://conceptsinmotion.net/store/store?page=shop.product_details&flypage=flypage.tpl&product_id=36&category_id=42
Option 7 : Omori Boost Gauge
Pros - boost gauge is on the steering column and doesn't block much of the tachometer (probably only the redline). also has a very slim design and does the cool spastic gauge sweep
cons - might be too bright compared to the cluster gauges
Price - $100 for the gauge with sender, an extra $30 for the pod, and if you speak with j spec you can get a $25 discount.
if you need more info on this boost gauge i'm sure burtomr will be glad to answer of your questions
http://www.j-spectuning.com/product_info.php/manufacturers_id/10/products_id/182
if i said something wrong just let me know and i'll change it. this was created so everyone can see some of the options on 1 page :thumbsup:
Price - around $150
Price - around $230
