Old 12-07-2011, 05:26 PM   #1
Optical TDI
Drives: GTI, S2000, Odyssey
VAG COM recommendations - shop will make changes for free
I'm going to get the APR flash soon and the shop will make all Vag Com changes that I want for free while my 2012 GTI DSG is there.
From my recent searches, I would like to do the gauge sweep on start up, fogs on with high beams, seat heater stay on same setting, maybe fogs while turning.
What are some other cool and useful items I should consider for my 2012 GTI DSG base?
Optical TDI is offline   Reply With Quote
Old 12-07-2011, 05:46 PM   #2
pdykstra600
pdykstra600's Avatar
Drives: 2011 SB GTI Mk VI
Disable the seatbelt warning and chime.
Enable windows opening/closing with key FOB
Increase the turn signal convenience function to greater than 3
Enable emergency braking lights
Autobahn Edition | APR Stage I | VCDS
pdykstra600 is offline   Reply With Quote
Old 12-07-2011, 06:56 PM   #3
allset
allset's Avatar
Drives: 2014 S5 & 2010 MK6
-disable DRL
-or lower brightness of DRL's
-or use fogs as DRL
-lights turn off with key if u leave the switch on
-gauge sweep- for fun
FOR PART OUT:|UNI KO4 #20 |Shaved Hood&Grille|APR Intercooler|Carbonio|KW V1|Peloquin LSD|Brembo GT 330mm|SB Stage 2 clutch| Centric Rear Matching Rotors|SNOW Methanol Injection|UR Catted/Res'd DP|Borla Catback|NEUSPEED RSe12 Hyper Black,KO4 TDP,TB Pipe,NEUSPEED 25mm & 28mm Sways,Support Brackets & Endlinks|Tyrol DeadSet Kit|R LED Tails|Klii Inlay|VCDS Tweaked||SupremePower.com|KMDTuning.com|GSE|
Old 12-07-2011, 07:06 PM   #4
michal
michal's Avatar
Activating "Tear-drop" function for the rear wiper
Deactivating the rear wiper sweep when in reverse
michal is offline   Reply With Quote
Old 12-07-2011, 07:14 PM   #5
pdykstra600
"tear-drop" function?
Old 12-07-2011, 07:17 PM   #6
omgturbo!
omgturbo!'s Avatar
Drives: 2010 GTI, blk full option - 6spd MT
.... que??
REVO Stage 1 | Neuspeed P-Flo intake | Custom exhaust | Eurojet Downpipe | Yellow Nokya Fogs | BSH mount insert | VF Engineering Short Shifter | Tiquan pipe (Noise Pipe Delete) | 30% Front, 3% Rear Tint | 1000w JL Audio Amp and W7 Subwoofer | Video-In-Motion | Klii Vinyl rear/wheel insert | Smoked Sidemarkers | Everything LED | VagCOM by me!!
I have VagCOM! | My Feedback Thread! | HellaFast Autosport
omgturbo! is offline   Reply With Quote
Old 12-07-2011, 07:22 PM   #7
michal
michal's Avatar
After using the rear wiper washer, the wiper waits a 3-5 sec and then does an extra wipe.
Old 12-07-2011, 07:25 PM   #8
michal
michal's Avatar
Originally Posted by omgturbo! View Post
.... que??
When you put your car in reverse the rear wiper is activated automatically (stock configuration) When you do not like you can deactivate it.
Old 12-07-2011, 07:27 PM   #9
omgturbo!
omgturbo!'s Avatar
YOU CAN DO THAT??
how? where in vag com is that
Old 12-07-2011, 07:32 PM   #10
Optical TDI
Originally Posted by allset View Post
-disable DRL
-or use fogs as DRL
I've seen that many like to disable the DRLs. Why is this popular?
Old 12-07-2011, 07:44 PM   #11
omgturbo!
omgturbo!'s Avatar
i have bixenon and it will make the ballast last longer. also, the lights flash when the parking brake is up.
its a cleaner look in my opinion. may not be suited for someone else.
Old 12-07-2011, 07:45 PM   #12
allset
allset's Avatar
some dont like the way it looks, some try to preserve the bulbs longevity.
The tear drop is an xtra wiper sweep after 5 seconds or so after u wash the rear window. it wipes the last bit that usually runs down the glass afterwards
Old 12-07-2011, 07:50 PM   #13
michal
michal's Avatar
YOU CAN DO THAT??
I'll post it later on. I do not remember right now which byte/bit it is. You can find it in 09 Central Electronics, Long coding helper for sure.
Old 12-07-2011, 07:54 PM   #14
omgturbo!
omgturbo!'s Avatar
sweet, i'll look tonight
Old 12-07-2011, 07:56 PM   #15
allset
allset's Avatar
YOU CAN DO THAT??
its in Central Electric - long coding. Dont remeber which byte but it says " tear drop wipe" in the wording of the check box
Old 12-07-2011, 07:56 PM   #16
steelcurtain
Drives: '12 Audi TT-RS
How do you increase the turn signal blink in VCDS > 3? I looked a couple weeks ago and couldn't find in long coding helper.
'09 VW GTI TSI APR 3+ - 11.53@121.18
'12 Audi TT-RS - Coming Soon!
steelcurtain is offline   Reply With Quote
Old 12-07-2011, 08:07 PM   #17
omgturbo!
omgturbo!'s Avatar
i believe thats in adaptation
Old 12-07-2011, 08:14 PM   #18
allset
allset's Avatar
All of below is found in 09 - Central Electronics.
1. Comfort Operation (via Remote Control) is in adaptation.
2. DRL is found in Long coding helper, depends on Halogen or Xenon (un-check the respective box):
http://forums.vwvortex.com/zerothread?id=4671558
3. Alarm Confirmation, Long coding helper, (un-check the respective box)
4. Comfort Turn signals, is in adaptation, choose the number of flashes.
5. Emergency Brake Warning active (actually uses 4 ways, described in above link) found in Long coding helper. (check the respective box)
6. I never activated that, but I believe "Tear Drop" Wiping for Rear Wiper is what you’re after, Long coding helper, Byte 21 (un-check the respective box) Any comments are welcome on that because mine was not coded from the factory and I don't know about the Reverse gear operation?
7. If you have heated seats...You may be able to set it up to resume the previous heated position on the Drivers seat after a key cycle.
Example: Shut the car off to run in the store, jump back in and start up, seat is still on the previous setting. Found in 08 - Auto HVAC, Adaptation from the drop down menu.
Old 12-07-2011, 08:20 PM   #19
omgturbo!
omgturbo!'s Avatar
will check this tonight and post results.
Old 12-07-2011, 08:32 PM   #20
steelcurtain
This explains it fOr me. I'm a 2009 model MKV with 2008.5 Ea188. No comfort blink option since that started on 2010'MY
http://www.myturbodiesel.com/1000q/a...-signal-vw.htm
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
