ericthered
New member
Howdy,
My shifting is no longer crisp after a VW software update - beware if you care!
As our 2009 Rabbit got over 34K miles it started jerking/clunking a bit when shifting into 3rd and 4th gears, particularly on downshifts off the highway. This initially created pangs of worries about DSG mechatronic unit failure (but then I found out it was a regular 6sp auto transmission).
Inspection of the fluid showed no sign of particles, and no other suggestion that there was any out of the ordinary wear. So VW applied "Campaign 24W4" to fix our issue. I believe this included reflashing the transmission and engine control units in the Rabbit (sorry, I don't know what they are called in VW land - this is my wife's car).
When I drove the car afterwards, they did indeed get rid of the jerking/clunking. And the shifting is sooo smoooth - or said another way, shifting is no longer quick and crisp. Ugh.
So I thought maybe this only happens in "drive" mode, and maybe not in "Sport" mode. Wrong again! I loved the DSG's shifting - now I can relax while in Sport mode and just watch the RPMs oozily drop at each shift point. Bleh and Double Bleh :thumbdown:
We love the car, but this is a sad step away from farfegnugen - and I would rather have it reversed if the jerking causes no harm.
More importantly, there must be physical changes/wear in the transmission that caused the jerking, and making sloppy shifts is a nice way to hide it. But the wear must still be there. Anyone else see similar problems, or had this firmware update?
So now I have a sloppier transmission with some premature wear, and I want to figure a way to make this better.
