DIY: tyrol brake caliper bushings and pad install
barische
Tools: caliper Tool,
Tyrol bushings
More to come as i complete this today
take off wheels and anti-rattle spring - w/ flat head
IMG_0330[1] by barische, on Flickr
Im pointing the cap of the guide pins that you need to take off - use 7 mm allen
IMG_0331[1] by barische, on Flickr
IMG_0332[1] by barische, on Flickr
take the caliper off and hang it by the spring via spring or wire/tie
IMG_0334[1] by barische, on Flickr
Pry off the old plastic bushings with needle nose pliers.
put in the new bushings - lube em up
IMG_0336[1] by barische, on Flickr
put it back together.. this is what it looks like installed
IMG_0339[1] by barische, on Flickr
AF-MKVI
Nice write up. How does it feel compared to stock?
FastTrash
Tell me what you think in 20k...
RacingManiac
I've had these on for maybe 8k miles now. The change in pedal feel IMO was minimal....I can understand why it might help, but I don't find it to be that tangible. Its a simple job though and real maintenance is just relubing and cleaning it. Which I am doing when I switch between winter and summer tire. Tyrol recommend regreasing them every 10k, so that falls in pretty nicely with my schedule...
TurtleJames
I've had mine in for a few months as well. It's hard to feel a difference on your own. But if you compare it with a stock set up, you'll notice it right away. Firms up the pedal a bit. This with sport pads and the VCDS mod makes braking feel a lot better than stock.
It's a simple install. You can change your pads while you're at it. It's a $100. No reason not to.
the bruce
:thumbsup::thumbsup::thumbsup:
corz123
Hey does anyone know if regreasing is really necessary every 10k? I'd rather not have to look at them other than when I'm swapping brakes.
grambles423
Automotive Engineer
Nope. I just grease mine when I'm down there every now and then
