slush.puppie
I have read through so my posts my brains is bleeding...
I have a 2012 gti w/ nav (xenon & led drls). I have oem vw led tail lights WITH REAR FOG, with adapters on a boat or plane from Germany right now. I have a euro switch installed, with the parking light trigger wire installed (from switch pin #3 to black cecm pin #19).
For the rear fog light to work, it is my understanding that I need to do the following:
* run trigger wire from switch pin #7 to black cecm pin# 17
* move wire from black cecm pin #28 to brown cecm pin #47
* move wire from brown cecm pin #47 to black cecm pin #28
* vcds coding under 09 central electronics, byte 18, change to either "04" or "21" (from what I've read, not sure exactly which one...)
Can anyone confirm or deny that what I have laid out above is correct? Thank you a million times over, in advance!
