arcboy2006
I wanted to put up a tutorial since i couldn't seem to find one. This is a pretty easy job and i kind of figured it out based on others suggestions.
**NOTE*** yes my car is dirty and yes the plasti dip as well.
Leave your hatch locked as not to open it accidentally while trying to remove emblem.
The bottom of the hatch handle has a little hole that allows you to insert credit card in through there.
You don't need to apply a lot of pressure, work the credit card around the outer ring of the emblem be careful with the clips!
At this point the Badge should be almost completely remove which will allow you to use your fingers to completely remove now.
You are almost done, i used some Mineral Spirit to clean the badge surface and it came out super clean, the the new badge just pops back into place with ease.
