dustinouch
This thread is long overdue.
Some background. I bought my car new in late 2010 and did a lot of mods early on. I got my stage 1 tune with less than 2,000 miles and now I have close to 30K. Then from 2011 to late 2012 I just enjoyed the car. Now a lot of the parts are getting refreshed exhaust, coilovers, wheels, suspension, brakes etc.
Engine:
APR stage 2 tune
APR Carbonio stage 1
APR DP
Akrapovic slip-on
GFB DV+
Transmission:
Diesel Geek Short Shifter
Tyrol Sports Shifter Bushings
VWR Subframe mount
Exterior:
SRS-Tec 25mm wide fenders
OEM Dark Cherry LED taillights w/o fog + ECS adapters
OEM License plate LED lights + BKS adapters
Votex (Zubehor) side skirts
Euro image wiper delete plug
USP 3000K HID fog lights
Weathertech window visors
Interior:
OEM 35th Edition shift knob
OEM Euroswitch
Stack boost gauge + New South vent pod
Suspension:
H&R Ultralows (temporary)
H2 Ohlins R&T VWS M100 + Eibach springs (shelfed)
H2 Camber Plates
Passat (aluminum) spindles
Superpro LCA
Superpro ALK
VWR Rear Sway Bar 24mm
White Line Rear End Links
VWR Front Sway Bar 26mm
White Line Front End Links
Tyrol Sports Rigid Collars + ARP Bolts
034 Motorsport rear trailing arms spherical bushings
Braking:
Stoptech ST40 328x30 + braided lines + Stoptech street pads
Stoptech slotted rears + Stoptech street pads
Chasis:
Unibrace XB
Unibrace UB
Unibrace RB
OEM R32 belly pan
Wheels:
SSR Type C RS 17x8 +48
Continental DW 215/45
42DD 15mm adapter/spacers
Volk TE37 17x7.5" +40
Fuzion (Bridgestone) ZRi's 225/45
To be installed:
OEM rear trailing arm covers
OEM rear axle cover
OEM RS3 brake ducts
US Mill Works license plate frame
Stoptechs rear lines
Tyrolsport Master Brake Cylinder
Tyrolsport Rigid Rear Collars
RE-Amemiya AW7s + tires
R-Line bumper conversion
OEM MK5 projector fog lights (Morimoto Matchbox?)
Frameless rear view
Radar detector
OEM cubby + sprintbooster
Rebuild Ultraleggeras
I'll update this thread as I get my pictures uploaded to Flickr. These are from last week.
The car sits higher since getting the new coilovers in. This is around ~25" FTG.
The handling is night and day with the Ohlins vs the KW V2, but if I'm honest I prefer how the car looked when I was lower. Sold the 18's now 17's only now.
I still have some parts that still need to go in, I'll update this thread with those and some of my older pictures.
Engine:
APR stage 2 tune
APR DP
Akrapovic slip-on
GFB DV+
Transmission:
VWR Subframe mount
Exterior:
Interior:
OEM Euroswitch
Suspension:
H2 Camber Plates
Superpro LCA
Superpro ALK
Braking:
Chasis:
Unibrace XB
Unibrace UB
Unibrace RB
OEM R32 belly pan
Wheels:
To be installed:
OEM rear axle cover
OEM RS3 brake ducts
Frameless rear view
Radar detector
