edward@becautoparts.com
August 19th Update
We are clearing out our remaining in stock headlights, we don't know if we plan to get any more in the future.
Option 1 - Golf R, or early GTI style, only 2 sets remaining at $400 a set shipped.
Option 3 - GTI-, all black style, only 2 sets at $425 a set shipped
To order, visit us at:
Check our website to order: www.becautoparts.com
Highlights
LED Controller issue has been resolved, so they wont turn off....it was a voltage issue with different LEDs that were being used.
We have a wire harness adapter so these headlights are more plug and play and to minimize any coding required. It is setup to work on the Option 3 and 4 headlights with the LEDs.
- LEDs will function as DRLs
- LEDs will stay on with the low beams
- issue with LEDs turning off is resolved.
- no need for coding to get these results
Coding will still need to be done if you want the foglights as your DRLs, or your want them disabled, etc.
Plus, we will have more options for HID kits, we will continue to offer the Morimoto Elite HID kit, as well as the good quality Hylux brand HID kits.
Thank you for your patience.
Ordering:
Visit my website at: www.becautoparts.com to order, or contact me and I can send you an invoice.
Coding:
Coding instructions are available for the regular Golf/TDI, GTI, and JSW models. Note, coding is different for each model, and can depend if you have fog lights, LED tails, etc.
Features:
Options available.
Option 1 - Golf R, Chrome, non-LED
This version looks like the current Golf R Xenon headlights, as well as the 2010-11 GTI model.
Option 2 - Black, non-LED
This version has the "fins" in the front in black.
Option 3- Black, with 15 LEDs
This verions looks like the current GTI model with the LEDs, but has black "fins" instead of chrome.
Option 4- Chrome, with 15 LEDs
This version is like the 2011-2013 GTI model, chrome with 15 LEDs
Ordering:
Please order at my website at: www.becautoparts.com
Or pm me, or email me at: edward@becautoparts.com
Include a phone # for the shipping label.
Warranty
The one year warranty covers manufacturing defects such as leds burning out prematurely, or other factory defects. Does not cover improper installation, coding issues, physical damage, or environmental conditions as described below.
I have sold a large number of these headlights since last summer, with only minimal issues. The issues identified by customers were:
1. Some water leakage and condensation. Check and ensure the seal around the headlight lenses are good, add some exterior silicon around any gaps. Make sure all the rear covers are on tight. This can happen with any headlight, even with OEM headlights.
2. A very small number of customers have identified the outer UV protective layer starts to peel after a year or so. A check of the locations showed they were from a "hot climate" where it is hot and sunny almost all the time.
Add a layer of lamin-x to the lenses if you dont live in an area with four seasons will help prevent this. If you have to leave the car outside all the time, this is a good idea. Glare from windows, or other reflective surfaces can cause premature wear, etc.
This is not a problem unique to these headlights, a Google search on "peeling headlight lenses" will get you a large number of hits from people having this issue with stock OEM headlights, as well as aftermarket. There are a large number of
aftermarket headlight polishing products that can help if you have this problem.
3. Some customers said there is some light leakage from the side of the headlights. This probably wont bother most people, but if you want, you can use a small amount of tape, vinyl wrap, or plastic dip the area to prevent light from shining out.
It really wont be noticeable after the install.
4. Sometimes the lights get damaged in shipping, I will replace anything damaged in shipping at no charge.
5. When you turn on the high beams, and than turn them off, the high beam remains on. There is a resistor inside that is defective, I can send you a replacement. It is a 10 minute job to unplug and plug in the new one.
Highlights
Ordering:
Coding:
Features:
- 10 pin headlight harness connectors, so no need for adapters.
- HID projector has the E-Code beam pattern, provides a sharper cutoff than the North American DOT pattern
- Uses D2H or H7 HID bulbs
- LED Parking light
- Turn signal bulbs are included (T20 size)
- Easy plug and play
Options available.
Ordering:
Warranty
