pure_lunatic
I'm going to tap the sump and drain my catch can via a one way valve.
If you do that then I wouldn't run the oil for very long... Fuel and water dilution are not desirable.
http://www.golfmk6.com/forums/showpost.php?p=181842&postcount=14
APR explains it themselves.
The fix he hints at makes a little more sense when you read that post.
APR isn't being secretive, APR is doing the smart thing and covering it's ass. If a representative of APR comes on here and gives a solution to a problem and someone screws up along the way...it's all APR's fault. I don't do it with the company I work for and I understand why *insert any company name here* does it.
Everyone on here MKV, and Vortex are like internet Gladys Kravtizes, the guy reaches out for help and GETS IT and everyone gets all pissy because APR didn't take out full page spread in USA Today detailing the fix.
thanks for explaining a little more, however - APR did in fact state on Vortex (its gone now, since they deleted their thread and all the posts in it) that they didn't recommend tracking the car at all, w/o this "special mod"/product they can provide/advise on later, but only if you called them and then they left it at that.
The fact remains, I've been in the tuning/car mod community for over 10 years and I've never seen a tuner or vendor make a weird ass vague statement like that.
Lastly, there is no "straw man" here - they never made argument in the first place, I'm simply critiquing how they handled the situation and their statements made during that situation. If you're gonna use hip new terms for logical reasoning and arguing, at least use it right.
Ah, found the follow-up thread on vortex based on the APR thread, where Arin was quoted as saying:
"Also, since this is a TSI, we've modified a few bits to make it race worthy... without those modifications, I wouldn't dare put a TSI on the track."
So, in conclusion, there was no "straw man" and you are in fact wrong.
I say skip APR and force VWOA's hand in coming up with a solution... A car driven hard wether it be a spirited canyon drive or the racetrack should not have blow bye this bad.
E46 m3's had a similar issue where spirited driving would cause oil starvation to critical engine components causing premature rod bearing failures... Causing ultimately blown engines.
BMW's fix?
1) extended engine warranty to 100,000 miles
2) inspected engines for signs of abnormal wear
3) replace engines if too heavily damaged
4) hardware fixes as well
BMW did this for all M3's wether or not they where tracked or heavily modified.
VW should do the same, although the nature of our cause is a bit different.
If I get premature engine wear from a trackday or spirited driving because of this oil issue... VW should fix and replace it... If this oil thing wasn't an issue and I blow my engine I'd take full responsibility...
If VWOA says that subjecting our vehicles to high G loads is outside normal operating parameters and can cause blown engines or wear issues... That would be bad press for VW.
I don't run R -comps yet but I've noticed signs of heavier blow by than normal at track days including oil level that drops and oil in the exhaust.
Imagine a post on autoblog or jalopnik saying VW GTI's can't handle high speed turns cause it leads to premature wear on the engine and blown engines... All the JDM fanboys would jump all over that.
Let's join together and get VWOA to come up with a solution/ fix.
Maybe APR has a solution and they are patent it to sell to VW as a fix...
lol @ "straw man"
Does anyone know if the FSI's had this issue or just TSI? I know FSI's had some beefier PCV fixes. TSI's currently do not have any.
Honestly this is a huge deal for me. I just started auto crossing this year and I plan to track a lot any chance I get (main reason I bought the car). If there's no worth-while/plausible fix then I might be looking at trading this in =/.
BMW's E46 M3 was due to contamination of the connecting rod bearings during assembly, not the same issue.
