Traction Devices
If you are required to have traction devices to drive, then getting some that clear the stuff in the wheel well is the problem. The brake lines, struts and stuff are very close to the wheel and tire, making clearance an issue. There has been several threads in the tire and wheel section of this website, discussing the various virtues of different approaches. I went with the SCC super Z6 cable chains. They have a very thin cable. Regular chains may be too thick to clear when the wheel is spinning. The one question with the Z6is the cables connectors which sit on the side of the tire/wheel. The worry is they will damage the wheel. Covering these metal buckles with something (tape?, Plastidip?) may reduce this problem. Some states, like Washington, allow the AutoSock, but I don't know about California.
