You ever mess with the factory pendulum mount, other than to possibly install a poly insert into one? The threads on the upper half of my mount in the subframe are somehow screwed up so the large bolt only threads half as much as it needs to, leaving half inch of threads still exposed when the bolt seizes. Really odd since I've had the bolt out a handful of times without an issue before. I have a new factory mount (both halves since the threads are in upper half) and bolt arriving tomorrow. I was wondering if you knew if the subframe must come off car to remove and replace the upper half of the mount, or if it can all be done underneath while on the car. I've seen how people cut out the lower half to install some aftermarket pieces, but the ones I've seen retain the threaded upper half.
Thanks in advance.
Sent from my SM-G920V using Tapatalk
Thanks in advance.
