Man wish we could post attachements, copied this from a PDF and clipped the image to my imageshack lol
2012 Volkswagen GTI (5K1) L4-2.0L Turbo (CBFA)
Vehicle > Transmission and Drivetrain > Clutch > Clutch Hydraulic System > Service and Repair > Procedures > 02Q,02QE,02QH Manual Transmission
CLUTCH SYSTEM, BLEEDING
System, Bleeding
Clutch
Special tools, testers and auxiliary items required
♦ Brake Charger/Bleeder Unit (VAS 5234)
♦ It is not necessary to pre-fill the system.
- Remove the air filter housing if the breather assembly -
arrow
- is not accessible. Refer to one of the following:
Gas engines
Diesel engines.
- Connect the brake charger/bleeder unit.
Use the Bleeder Hose (670 mm) (VAG 1238/B3).
- Connect the bleeder hose to the brake charger/bleeder unit collector bottle.
- Connect the bleeder hose -
A
- to the breather assembly -
arrow
- Apply 2 bar (29 psi) pressure to the system.
- Open the breathe valve approximately 1/4 turn.
- Press the
clutch pedal
15 to 20 times rapidly by hand from stop to stop.
- Close the breather valve and turn the brake charger/bleeder unit off.
- After completing the bleeding procedure, and the pressure has dropped from 2 bar (29 psi), press the clutch pedal an additional 10 times by foot.
- If removed, install the air filter housing.
My next guess would be the slave cylinder. Just had a similar issue in my 944 it wouldn't grab when started in gear but once you put the clutch in and selected a gear it would not release the clutch, so putting it in neutral then it would take off. Of course the pedal also would not come back up, but new MC and new slave and works like a charm.
