torga
Unfortunately, my third-hand set of Osrams are immediately giving me issues. And it's a strange issue. I'm dead set on fixing these, because I think these headlights are worth the trouble.
When the car is running and the headlights are not on, the DRL lights work flawlessly. From the manual, it says the DRL are supposed to dim when the low beams get switched on. However, when I switch the low beams on, the passenger-side DRL simply shuts off (within 3 seconds) – the driver-side remains operational. The other LED light in the passenger-side housing also turns off when the low beams come on (the smaller, innermost light which is in the same spot as the stock high beam in the halogen housing). The low beams are unaffected by this DRL failure, the turn signals remain operational, and the high beams remain operational. When I switch the low beams off, the passenger side DRL turns back on like nothing happened. There is nothing wrong with the driver-side headlight.
And here's a kicker -- this is only an issue when the car is running.
When the engine is off and only the accessories/electrical systems are on, the headlights work flawlessly. Both DRL lights stay on when the low beams come on.
Since there is a voltage delivery difference between these two car states (~12.5V when the engine is off and ~14V when the engine is running), I’m curious if this signifies any failure from within the headlight, perhaps a loose connection somewhere or a faulty LED controller?
I've already checked simple things, such as fuses and loose headlight connectors. There doesn’t seem to be anything obviously wrong with the car-side connections. I also reached out to Osram to see if they've got any insights.
I do get a gauge cluster warning light when the DRL fails. It resets itself every time I turn off the car. These are the related codes I pulled:
- Light Switch (implausible signal), Code 02395
- Terminal 30 right (open circuit), Code 00927
- Terminal 30 left (open circuit), Code 01516
- Left low beam headlamp bulb (open circuit/short circuit to B+), Code 00978
- Left high beam headlamp bulb (open circuit/short circuit to B+), Code 01495
- Left DRL bulb (open circuit/short circuit to B+), Code 02745
- Right DRL bulb (open circuit/short circuit to B+), Code 02746
- Bulb for left front parking light (Faulty), Code 02394
- Bulb for right front parking light (short circuit to ground), Code 02395
