PeeLo801
Do you have a way to see what the CEL is for? Are there any other lights on, such as a steering wheel symbol? It is common to have a steering wheel fault when disconnecting the battery -- that problem will go away after driving at a slow speed and turning the steering wheel lock-to-lock a few times to allow the car to relearn the steering wheel stops.
thanks. Yes the steering wheel light was on too and it went away.
Used an OBD scanner and found P025c code. But we just cleared it. Crisis averted. :thumbsup:
