Thumper
So I recently came back to the Mk6 fold picking up a 2012 Golf R, previous owner had the DRLs turned off in MFI, however checking the box did not activate them (though it did cause the "DRL" light in the dash to illuminate when disengaging the parking brake with headlights off). I checked the coding and all appears correct, although I can't tell if the 'dim' setting in the module is accurate, it's set to 100 which to me means 100% dim, but I've found other threads that say that 100 is full bright and 0 is maximum dim.
However, the DRLs do not light up either with headlights off or when they are turned on as parking lights. I had to do the factory reset in the MFI for it to accept my setting for the comfort turn signals and thought that might jog the DRLs loose too but no luck.
My only thought is both lamps are full on defective but would think that would trigger a bulb out error? Or does the system not check current on them since they are LED?
