dustinouch
New suspension parts went in this past weekend Unibrace UB, VWR rear sway bar, and White Line rear end links
Not pictured was the allen wrench I needed to remove end links.
Close up of the White Line end links.
VWR Sway Bar comes with teflon lined bushings, similar to the H&R bars.
Left and right side installed.
No pictures of the UB install. There was almost no clearance because I was only using 2 jack stands instead of 4. Hardest part was getting the UB under the rubber.
The car feels less composed, not what I wanted. I suspect that the rear sway is overpowering my struts rear damping. I'll need to play with my settings. The end links and rear sway also very tight to get in. I'm thinking I need to adjust on ramps with the suspension loaded.
