Electronics issues
meah1t
Location
Millie01
Car(s)
Vw golf gtd
Please can anybody help.
Had water ingress to boot months ago, now all clear.
Last week boot wouldn't open suddenly, no power sounds. Tried to change actuator and latch but didn't resolve.
Next day keyless entry has stopped working and need to hold key to steering column to start car. Fob batteries on both keys not working and changed but didn't resolve.
Start stop error message is only message on info but no reason.
OBD plugged in and showing following:
CAN network gateway fault 131634 access/start no communication
Engine fault 23132 access/start authorisation no communication
Central electronics 538389 databus missing message
Steering column lock 13634048 databusmissing message
EpicTech
Location
Houston
Car(s)
MK7 GTI 6sp w/PP
That sounds suspiciously like the ECM/ECU. Have you tried disconnecting the battery for about 30 minutes and then reconnect? Curious to see if this will help. If you get same errors then it would seem to me that the ECM is faulty.
