I have an engine vibration I'm trying to figure out on my 2010 GTI 6MT. It's strongest at 1100 rpm, almost unnoticeable at 900 rpm, but can generally be felt to some degree all the time. I did the following maintenance since it started (I was already planning on doing it before it started), and there was no change:
-replaced timing chains, tensioners, and guide rails
-resealed cam girdle
-carbon cleaning
-replaced plugs
The passenger side engine mount looked good when I had it off for the timing chain. I haven't checked the driver side mount or the pendulum since doing the clutch 2 years ago.
I don't feel any vibration in the clutch pedal. So, I don't think it's the flywheel.
The computer isn't showing any misfires. I don't feel any hesitation when accelerating.
I've seen some people in other posts say some vibration is normal. This is definitely beyond normal.
What should I look at next?
-carbon cleaning
-replaced plugs
