Golf R DRL problem
kybzk
Hello everyone.
I have a 2011 Golf MK6R and it has a problem with the DRLs. Whenever I turn the ignition on and start the car, both of the DRLs turn on and after roughly 5-10 seconds, the driver side DRL turns off. However, when I turn the light switch to the parking lights, both turn on, but are dimmed, as they should. Now when I turn back to OFF position, both of the DRLs turn on again, and after 5-10 seconds, the driver side DRL turns off again.
Fast-R
I had the exact same issue. There are 3 wires at the connector of the LED DRL. Jump the outside wires to each other and your problem will be solved.
