I'm just curious. What are your IAT temps like blocking most of the front of the grill? Why not make an oil cooler on one of the side Fog light openings?
I didn't think about IATs in relation to smaller tracks with more off-throttle time when the IATs creep...maybe that's part of the reason my IATs seemed higher than I would have thought at Dominion which is small.@Redslaya 's car has zero perceptible difference (all within noise of variance for track layout, etc) vs other cars as far as IAT goes on track.
For reference what I'm referring to:
Redslaya's car with the oil cooler and duct when tested at Palmer:
Vs the Black Cat Racing sample at Road Atlanta - same intercooler, same main radiator, same turbo:
The 2 deg diff in IATs is negligible when comparing all other samples, and because Palmer is way less WOT vs Road Atlanta (note the big difference in TPS % and top speeds), I'm sure that they'll be even closer when he gets back to VIR.
If you look at my samples (Derhase 2 and 3) - those are on two different tracks, same car. The smaller/windier track (Summit Jefferson) produces higher IATs - less time is spent on throttle, so the IATs will creep up when in the corners or coasting, etc. Tuned and untuned isn't a huge difference in IATs overall from the looks of it (I'm sure if we get some samples with big hybrid turbos then it might start to show up more).
Realistically any given temps can be taken as +/-5F accuracy, especially when it comes to IATs. If I didn't know that the car had a ducted oil cooler (and oil temps weren't shown), you'd have no way of knowing it was there.
I suspect on the topic of airflow, that these cars are just not moving a lot through the cooling stack. I REALLY want to get a car in the wind tunnel at some point. Would answer a lot of questions.
ALSO, looks like Jeff got a hold of a CSF radiator. Externally it flows 20% more air which I wasn't expecting. The unclear results (especially on nearly stock cars like @q74 's first sample) seem to indicate that whatever benefit *might* be there is not immediately obvious. I've been having everybody log coolant outlet temp on Simos Tools ever since I figured out it can be added in Mode 22.
For the few cars that have logged it (including @Redslaya ), coolant outlet temp is essentially within 7F of engine coolant temp at any given time as soon as you're on track for more than 2 minutes (if that, more like 100 seconds, see the screenshot below). Most of the stock radiator cars lower the coolant temp by 8-10F for comparison. His car isn't a good direct comparison to any others (for coolant outlet temp specifically) because he has the oil cooler doing a lot of the heavy lifting, and again it really needs re-evaluated at VIR for coolant temps overall.
As always, more samples/testing is needed.
*le sigh*
Interesting, thanks for the graphs. Has anyone eliminated the rear fan shroud? It would seem a lot of airflow could be gained if you just mounted 2 fans instead of using the fan shroud.@Redslaya 's car has zero perceptible difference (all within noise of variance for track layout, etc) vs other cars as far as IAT goes on track.
*le sigh*
I thought the same thing but the data show a different story which was surprising....I mean, you have that huge-ass bumper etc. and upper grilled that nearly blocks all flow...amazing these cars run at all ahhahaahahahI'm just curious. What are your IAT temps like blocking most of the front of the grill? Why not make an oil cooler on one of the side Fog light openings?
For sure but then you have to drive aroudn town when it's 95 out and your cooling efficiency has to be worse in those conditions...all a trade off with a daily that sees track use.Interesting, thanks for the graphs. Has anyone eliminated the rear fan shroud? It would seem a lot of airflow could be gained if you just mounted 2 fans instead of using the fan shroud.
What about oil temps?Link to final testing here for future reference:
https://www.datadrivenmqb.com/drivetrain/oil-cooler-duct-conclusionresults
Traffic in his run group kinda sucked for getting good data (and you can see the slow down going through the climbing esses)... but bottom line his car is doing 8-9mph faster down the back straight now like an IS38 car should be doing. It really doesn't get a whole lot more conclusive than that. I think 133 or 134 is the fastest I've seen in any of his prior logs for reference.
