Chris@Revo USA
I REVO'd my 2011 GTI today too and I feel a difference but it doesn't feel that great. I was expecting a really dig difference. I called a few of my friends and all of them said to give the ECU 5 hours of driving time to adapt and I should see a huge improvement.
Like on thing is noticed was the tires wouldn't even screech of a 20 roll I thought with all that torque that it would be crazy
The gains are instant. The adaptation thing is really from back in the day with dumber ecus and normally aspirated engines. There will always be some adaptation even a bone stock car adapts every time you clear codes but 99.9% of the gains will be there immediately.
There may be something up with your car such as a failed dv, charge pipe leak or even a PCV issue. Your best bet is to find someone with VCDS or head back to your dealer so that they can do some logs with your car to see what is going on.
Generally there isn't much of an issue with gas applications but upon releasing our 2.0 tdi software over a year go we realized that lots of people weren't driving the cars right. Yes I know that sort of sounds like an excuse but isn't. If you look at the dyno charts while there are gains at 6K rpm the meat of the improvement is throughout the lower and middle parts of the power band. Up top no matter what you or anyone else tries to do the turbo is just too small and power falls off. If you are winding it out the gears to 7,00 rpm you'll end up at the end of the power band once you get into say 3rd or 4th and no you really won't feel much because the car isn't making power there. Shift at 6,000-6,500 rpm and you'll end up right back in the meat of the power band. Many of our TDI customers were coming from gas engines so they were thinking flash the car I get more power but it was still within the limits of that engine, they were trying to shift past 4K rpm so you would end up in the next gear after the power had fallen off and feel nothing. Tell them to drive it like a diesel and they would call back ecstatic.
