MK7 "Random / "Stupid" Questions Thread"
Pineapple
Location
Boston, MA
Car(s)
2017 Golf GTI S
I've had a weird navigational issue that can be pretty vexing when it strikes.
Has any ever noticed their gmaps navigation sometimes having much less precision when plugged into carplay? It's been an ongoing issue where the nav will lose my position, sometimes on complicated roadway situations like below ground on i93/i90 in Boston, but also sometimes on typical surface city streets. It freaks out because it doesn't know what street I'm on, assumes I'm teleporting around, and that I'm in desperate need to get back on track. meanwhile I'm missing my exit because I have no nav support.
I've had my passenger take out their nav assuming it was my phone, and their gmaps worked fine in those scenarios up until we connected it to carplay and then it too bugged. I'm not sure if being connected to bluetooth but not carplay yields different results.
Kushdaiin
Location
Connecticut
Car(s)
MK7 R, MK7 GSW SEL
I have had this happen in and around Boston as well. The tunnels get kind of weird especially because you might have surface streets above you and the GPS nopes out of the chat. I've also had the teleportation happen at the airport where it just can't quite figure things out. Both have been while I'm connected to Carplay.
victorofhavoc
Location
Kansas City
Where is your phone sitting when connected? Remember that the GPS chip in cellphones is buried in the phone and because of their cheapness and security concerns they are strictly limited to 1hz polling, below 10000ft, slower than 300mph, and no closer than 3m of precision. This is done to prevent people from making cheap/homemade self guiding missiles. This means at 60mph your position can easily be 88ft off, even with perfect signal. Typically you're getting position from 5+ sattelites and these days the Russian sattelite position system is highly hit or miss for obvious geopolitical reasons, so it's more common to drop a sattelite here or there. You can also get interference from too short of a cable (high amperage while charging and transferring data will cause magnetic interference and a shorter cable limits the position of the GPS sensor and cable)
You can look into where to place the phone for better signal, use a longer cable to get it away from the cubby surrounded by electronics, or possibly put some farady beads around either end of the cable to limit magnetic interference. You can also lightly knot your cable a few times on both ends to accomplish a similar functionality to farady beads.
I've had similar issues with it, but using the wireless AA adapter solves most of them since I can sit the phone in a chest pocket, cup holder, door, or seat next to me. It can still get wonky if near big power lines, overcast days, or other interference is around.
Pineapple
Location
Boston, MA
Car(s)
2017 Golf GTI S
Science! 🧑‍🔬
Here's my magnetic holder:
It's only a problem very occasionally, and while it happens in areas you'd expect like underground it's also happened on pretty average streets. It's also 100% linked to being in carplay because unplugging it solves the issue almost immediately. I wonder if there's a different method of location finding depending if it's in carplay or not.
victorofhavoc
Location
Kansas City
Science! 🧑‍🔬
There's no functionality I'm aware of in carplay or android auto to use the built in vehicle GPS vs the phone GPS when connected to a head unit. I'm pretty confident in that since cars with no native nav system and Android auto/carplay exist and work just fine.
The magnetic holder could cause a bit of issue with the sensor, but if it instantly works fine when unplugged, I'd try another cable or tying a few knots in an existing one to see if it helps.
There IS significantly more processing going on when using these systems, especially with nav enabled, which I'm sure you've seen with power draw and heat generated. When the screen mirroring is occurring there's even more processing to remotely display over the phones only port interface. That can impact quite a bit as the phone system attempts to manage power, data, image painting, etc over a single USB connection. IPhone is much more aggressive about power management than android and doesn't do as well with background processes as a result.
krs
Location
Las Vegas, NV
Car(s)
MKVIIS R
My wireless CarPlay adapter has the option to use vehicle GPS, or phone GPS.
There’s an issue with the vehicle GPS in my Atlas, causing terrible amount of drift, so I switched it to the phone and worked better.
Guessing the wired setting that option isn’t there? ¯\_(ツ)_/¯
victorofhavoc
Location
Kansas City
How do you set that setting on the adapter?
I'm aware there's been some progress towards using the headunit GPS, but I wasn't aware any manufacturers have actually done it so far. That would involve allowing data to leave the head unit's interface, and I didn't think any manufacturer had allowed that level of permission... Yet...
I do now that vehicles that have Google maps built into their interface, like some audi, Porsche, and volvo use the on board GPS, but from what I've seen when using AA or CP it was still using the phone's GPS. Potentially it might be trying to use both if it can?
Kushdaiin
Location
Connecticut
Car(s)
MK7 R, MK7 GSW SEL
I’ve observed and used this setting on my dongles as well.
krs
Location
Las Vegas, NV
Car(s)
MKVIIS R
I can’t speak to anything that you’ve mentioned, as I just don’t know.
My GPS setting is in the adapter settings.
Ezekiel81923
Location
Royersford, PA
Car(s)
2019 Volkswagen GTI
Had a PR MPI kit and continental ethanol sensor installed yesterday. Not getting an ethanol reading on my AP or in SimosTools. Well, I get one, but it's 0.00 and I assume even 93 would register even a little ethanol.
I have the wiring instructions for the MPI kit but not the ethanol sensor. How do I double check everything is wired right? MPI is not activated yet but I get an MPI FR pressure on the AP so I know some of the stuff is wired right. I have not done a firmware update on the AP but assumed I did not need to because a) the monitor was there and b) SimosTools reads the same.
swcrow
Location
Virginia
Car(s)
7.5 GTI
Correct......you would get an 5-11% reading even on 93. Mine was wired up perfectly but until I reflashed with ethanol content reading opened up, my AP wouldn't read anything the sensor was sending. I'm not on Simostools, but assuming wired correctly, prob a setting in ST you need to double check....did you add a PIN in your ECU for this? I had to
@Diggs24 paging ST expert......
JTM88
Location
Broken Arrow, OK
Car(s)
2016 GTI
Do you have any suggestions for SS brake lines, brands to avoid, or any brands that are better for some reason?
victorofhavoc
Location
Kansas City
If they don't have a DOT certification stay away.
Anyone with a DOT certification (and label) is fine.
Even with a dot cert I had a line fail on track and result in a tiny/slow leak that caused severe fade at even low speeds. I see it as a freak accident, but it's always a risk with any part.
