I’m about to pull the trigger on a digital dash from a golf r. It’s used and I can get the trim and whatever cables are hooked up to it. What would I need to do besides just plugging it in and going? I have an mib2 car
Regrettably, it is not a direct plug-and-play kind of retrofit due to security mechanisms for the immobiliser. Besides the wiring and trim, you would have to have the immobiliser paired to your car and then have your keys recoded to the new immobiliser. This requires the dealership software, ODIS, with online functionality. Since the cluster is used, VW requires that it be scanned by a dealership or independent shop with ODIS and then have a form sent to Germany for the cluster to be approved for activation with a new VIN. The approval process takes up to 48 hours and then the immobiliser can be paired to your car using ODIS.
I have seen claims that there have been periods when VW stopped approving used immobilisers but can't comment on that.
you can also take it to a shop that has odis access or use an online programmer such as @simaservis1108. his telegram/whatsapp is on the profile. you would need to rent a vas5054a dongle and need a windows laptop. he will connect via remote tool to program your new dash (diy install). the only thing that is not possible is rolling the odometer to match your actual mileage. only unused units can be set to a custom mileage. otherwise, the mileage locks in after 30 miles or so of driving from 0.
Cluster can be hooked up to a bench setup and have the miles run up that way; obviously only works if the donor car had fewer miles than the recipient.
Did this with my 2016 R. Thankfully had no issues of and kind. I updated my head unit to the 9.2", upgraded the glove box to MIB2.5, and also connected the harness to pass maps to the cluster.
No worries for component protection. I just needed to find the right people to help with the upgrading and ODIS access. The dealer said I couldn't do it.
Looks good as always. The dealer did mine, and plenty of other people's. It's always strange to me when dealers say (with such certainly) something can't be done, especially things that have clearly been done .
