rough idle
landlubber
help.. just did a cam follower install, put it all back together now the car won't idle. Could this be a bad vacuum generator?
Black13R
I would go in and retrace the cam follower job you just did. Check and make sure you did crack any of the pcv hoses or displaced any vacuum lines in the process. Either of these will have a big impact on idle. The chances of the vacuum generator going bad while your doing your follower are slim so I’d look into that if all else fails. Good luck
