phd-12v
That's cool. I think the side mount subs give you more options in which driver you use, but I really didn't want one there. They use up more space than the under floor model that I'm doing.
You're quite knowledgeable in these things — what do you know about my post right above yours?
your findings are 100% correct. The factory radio does this to protect the speakers, and basically it is almost like an automatic loudness contour. You would need to get a cleansweep or bit one to analyze the sound, then modify it, then output it to the amplifiers. If your only using the sub amp, that could get expensive to just restore the bass equalization the factory radio does.
I did once use the MTX req and that seemed to help out alot on another vehicle i did where i had to tap into the factory speaker outputs.
Audiocontrol has some pieces i have had real good luck with in the past also.
http://www.audiocontrol.com/index.aspx
