I'm getting pretty psyched to see what the Unitronic tune can do. Not so psyched about dropping another $750. Gotta pay to play as we always say.
Having my Snow kit pulled tomorrow and replaced with a Coolingmist. Going to keep my 60cc at the TB spacer and replace the 175cc with a CM5 post IC. I'll see how things feel with the APR 100 octane file, but will probably get flashed to the Unitronic Stage 2+ next weekend. I have the partial throttle 2 - 3k stuttering issue. Cylinder 2 and sometime 3 generate misfires on my APR K04. Plugs and coils have not helped. The issue remains on cyl 2.
The good thing is, my shop is tuning the kit on a Mustang dyno. I'll be able to have a baseline to compare to when I get tuned for the w/m from Uni.
You won't be disappointed!! :thumbsup:
Go you think the cm5 in to big in the TB spacer ? Only nozzle I'm going to run.
I'm not really the guy to ask. I just do a lot of research before I invest in stuff and base decisions on other folks experience. From what I have read, I think a CM5 would be too much at the TB. I'm sure someone will chime in and provide detailed info.
What's the flow rate of the CM5?
It flows "280-340cc/min" according to Cooling Mist's site.
I think that's too big for a single post TB nozzle. The goal of a post-TB nozzle is to fully atomize in the combustion chamber to provide maximum detonation suppression/octane enhancement. Since there's a very short path to the combustion chamber on a post-TB nozzle, you don't have much time to atomize the mixture.
On the other hand, a dual nozzle setup can accomplish both charge air cooling AND octane enhancement if done properly. You can run a larger nozzle (when compared to the post-TB nozzle) post-IC. The goal of a post-IC nozzle is to atomize in the charge piping, which will reduce the charge air temps. But, since the mixture will be fully atomized (if nozzle size is proper) in the charge piping (pre-throttle body), it won't provide any detonation suppression/octane boost. That's where the post-TB nozzle comes in. You can run a smaller (when compared to the post-IC nozzle) nozzle post-TB, that will allow the octane enhancement since atomization will be seen mostly in the combustion chamber.
Hyde16 did some checking for ko4 with our mods and something like 175 cc/min at the IC bung and 60 cc/min at the post TB spacer was recommended
ok cool. thanks guys for you input :thumbsup:
Reading these threads makes me feel lucky to live 10 minutes away from Unitronic HQ.
Should be finishing up my K04 install today and going in on Monday for my software upgrade :thumbup: Can't wait!
