realcyberbob
Does anybody know if there's a vag-com mod so that you can use the MFD while driving?
The MFD works while driving.. only thing that doesn't work is changing the settings etc.
keep your eyes on the road :thumbsup:
Nobody has elaborated on the auto lock question at the beginning of this thread. What does auto lock mean?
^ That's a Europe thing. In North America we have sensors in each wheel, at the valve stem, to measure the air pressure.
I'm pretty sure I enabled that option on mine. You don't need a rain sensor. Just go through the VCDS and there should be an option. I'll check later and update if it's possible.
This is not entirely true. It depends on your car. I have the indirect sensors that are located on the ABS unit. The esiest way to determine if your TMPS is on the brakes or in the wheel is by looking at your wheels valve stem. If its rubber your sensors are part of your breaking system. If the valve stem is metal your sensors are in each tire. I live in VA and have indirect sensors.
Indirect vs Direct.
Wow, you sure dug that one up pretty good.
Allow me to clarify my statement from 1.5 years ago...
2010 USA models had direct TPMS - i.e. sensors in each valve stem.
2011 and onward use indirect TPMS
But the 2010 models still have the indirect tpms ability. I just activated mine last night. The key is to turn the original direct tpms module off and then turn the indirect on.
Saturday,15,October,2011,16:39:57:60994
VCDS Version: Release 10.6.5
Data version: 20110930
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 65 77
VIN: *******************
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
[B]19-CAN Gateway -- Status: Malfunction 0010[/B]
1C-Position Sensing -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
[B]56-Radio -- Status: Malfunction 0010 (???)
65-Tire Pressure -- Status: Not registered 0011[/B]
77-Telephone -- Status: OK 0000
SNIP!
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0231
Revision: H16 Serial number: 4320K09A190960
Coding: E9801F06001612000000
Shop #: WSC 01357 011 00200
VCID: 69F770C039E2
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 3
Reset counter: 1
Mileage: 58964 km
Time Indication: 0
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0034
Revision: -----19S Serial number: *************
Coding: 0100040004
VCID: 61E768E0C1D2
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 193
Mileage: 57617 km
Time Indication: 0
Date: 2021.14.23
Time: 21:35:55
Address 65: Tire Pressure (J502) Labels: Redir Fail!
Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
Component: RDK 103 0521
Coding: 000000
VCID: 354FECB025DA
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
SNIP!
End ---------------------------------------------------------------------
http://www.myturbodiesel.com/1000q/a6/activate-tpms-system-vw-golf.htm
Go halfway down the page and read "How to swap from the direct to the indirect TPMS system or disable the TPMS system"
That should get you there:w00t:
Yeah, I've tried that. I still get the CAN-Gateway malfunction error. I assume it's okay. I just need reassurance.
