NewGuy1
Hi Guys,
Seen this issue pop up in a few threads usually without any resolution.
I bought some Vland UU headlights and like many others my DRLs did not work after install.
Despite searching the forums thoroughly i did not see anyone post a solution besides buying "adapters" that may or may not fit.
This is NOT a coding problem or a headlight switch problem, I figured that out after hours of trying to code and debugging.
The fix, at least for my headlights was a pin swap. Parking lights on the original 10 pin harness is pin 10.
Pin 10 on the VLAND headlights are not the UU DRLs.
It seems like the pin is part of the auto adjustment system and pin 1 is actually the DRLs.
I swapped pin 10 to pin one in my clip and got my lights working no problem now.
Hoping this helps some of you out there.
