rizzogti
18x9 et 32 all around is it do able? cars on air would run a 215/40
Easy... Run a 205 up front tho.
Finally chose my new set of wheels 18x9 et 45 all around. question is though will they fit fine or will I need to run spacers front or back I'm picking them up this weekend
You're fine. Get 215 tires though since you're on air
just trying to see what you guys think. I will be running 17x8/9 et 38/45 respectively and i will be on air too. would i be able to tuck those in and pull the proper fitment with 205/40's all around? will i need camber in the rears?
Thanks!
If I was you I'd just keep the stock 225
Rims on the way 18x8.5 Et45 square. I'm at 24 ftg on coilovers. Wanted to know best tire size to get without rubbing. I was thinking roll the front and 215/40 r18 evo v12?
