I run one in KSA (Saudi) even at 46C ambient the oil temp runs 98-108 C.... It will climb a few degrees up an incline at constant speed such as the Bahrain causeway ... fun to watch ! "Jeddai " (get it?!) has 30 kkm on him.
Depends on where its measured. More than likely in and around the motor the temp is sufficient to remove the residual moisture that develops when the car is not being driven.
