E36 M3 Project Car Build
TheGTIChannel
Like others on this forum, I am now the owner of a non-MK6 car, but liked this forum so much I decided to stick around a little bit longer ;).
The car I bought on 8/17 is a 1995 BMW E36 M3 with 140k Miles. Since it's a '95 it has the OBDI 3.0L S50 engine rather than the 3.2L S52 that came in 1996. The car has had 6 owners but has a clean title and Carfax with no accidents reported. It was originally Dakar Yellow but has been re-painted "Lamborghini Fly Yellow" along the way :). It is one of the few US E36s that were made with the hurricane interior. One of the previous owners fitted an unbranded exhaust system that I ended up being quite fond of. As awesome as the APR TBE sounded on the GTI, the old BMW I-6 is one of my favorite engines in term of exhaust notes.
My goal with this car is to go for a daily driver that will be 80% street, 20% track oriented. Handling and performance will be my priorities. I will also address any interior/cosmetic issues as I go along with the project.
Overall, the car runs quite well for its age. Current *functional* known issues that I will have to address (I will update this list as I discover more problems):
-Rear trailing arm bushings are destroyed. *FIXED*
-Front control arm bushings are worn. *FIXED*
-Rear subframe bushings are worn.
-Needs front and rear subframe reinforcements.
-Power Steering is leaking. *FIXED*
-Rear passenger output shaft is leaking. *FIXED*
-Belts are worn out. *FIXED*
-Springs/shocks are shot. *FIXED*
-Sway reinforcement tabs need to be addressed.
-Tires are bald (fixed).
-Worn down front/rear pads and rotors. *FIXED*
-Windshield wipers are worn out. *FIXED*
-Windshield wiper pump broken.
-Missing screws everywhere.
-Turn signals malfunction. *FIXED*
-Fender liner is loose and rubbing on tire. *FIXED*
On top of these are all of the cosmetic things that must be addressed such as rips in seats, trim missing/falling off, etc.
Some cell phone photos from the this weekend:
TheGTIChannel
Let the fixing begin...
Day 3 of owning the car. As you can see the original tires were done with. The previous owner (worryingly) used the car for amateur drifting. Fitted the car with Hankook V12s (Front- 225 40ZR17, and Rear- 245 40ZR17). Grip heaven :happyanim:.
I also picked up an X-Brace for a steal of a deal and had it put on while the car was on a lift. This is an OEM brace that can be found on the E36 Lightweight and Convertible models. Offers more rigidity than the original bar.
I also got new Bosch windshield wipers since the OEM ones couldn't do their job anymore...
More to come! :happyanim:
D Griff
Man, I really love this car, it looks great in that color. So you sold your VW? This '95 is your only car? Brave man! I'm excited to check out your progress.
T is for TURBO
Looks nice for it's age! The 36 M3 is my favorite generation so far. My dad has a 98 328is, and it certainly is not my favorite car to work on :D But for as slow as they are, they sure are fun to drive!
Also, wtf is up with those goofy tail pips I see on almost EVERY e36?:yikes:
maxtdi
Sounds about right for the average e36. I hope you paid less than 7k for it in that shape.
Was the cooling system replaced yet?
Also use pelican parts they are good peeps.
TheGTIChannel
Thanks! I wasn't to sure about it, it draws a lot of attention (pulled over twice in the three days I've had it), but t won me over. Gives the car character :p.
Favorite gen for me as well! I like the square look. I actually like the look of the tail pipes :iono: to each their own I guess!
Sounds like a lot of work but it does look cool, good luck.
The work is part of the reason for getting it :D. I enjoy a car that keeps me busy. And Thank You!
Got it for 5.5K. Cooling system is stock. It's on the to-do list.
maxtdi
5.5 is really not a bad deal for that esp if the paint job was done well.
