audria@blackforest1
GolfMK6 Official Vendor
On top of our already great selection of wheel spacers, we've added even more sizes and styles so that you can dial your fitment in to the millimeter.
With two great finishes to choose from, lower prices, as well as a detailed removal notch, these are without a doubt an essential upgrade for your car. All spacers are
offered in hubcentric bores specific to your VW or Audi.
Our blasted and clear anodized silver finish is great for OEM applications and they will disappear behind your wheel without drawing attention to the
fact that you've enhanced your stance. But if you've gone the more aggressive route with a custom finish and are looking for a compliment to those pricey rollers, our
blasted and black anodized look will definitely do the trick.
Not all spacers are created equally. Our new line takes careful consideration of the details. That's why we've included a machined relief that is specifically
designed to help aid you when it comes time to remove your spacers. If you're new to the spacer world, you might not realize that it's easy for corrosion on the brake rotor surface
to cause your spacer to seize. While ultimately most people are concerned with a spacer staying put, you also want it to come off when you want to.
We make it easy to pick the necessary wheel bolts for you application. Simply select either ball or cone seat in the drop down menu when placing
your order. Most OEM wheels will use ball seat, while the majority of the aftermarket wheels use cone. Choosing the right bolt is important to ensure a proper fit and we make it as eas as possible!
We've Lowered Our Prices. :thumbup:
Even though we've improved the product, as well as expanded the number of finishes and fitments, we've also managed to lower our prices across the board! So if you're in the market
for these guys, make sure to compare as we're confident we have the best product, for the best deal- period.
