Frank@KMD1
Presents:
P3Cars Vent Integrated Digital Interface!
(MK6 US GTI version shown)
Also Available White and Red LED option!
And Golf R White and Blue!
Track Pack now available!!
Product Information
Connect with your car in an entirely new way. Why settle for just a boost gauge? Sporting features available in products 3x the price, this is a swiss army knife of performance data, with design and integration that won't spoil the clean lines of your interior.
Reads boost and all data directly from the diagnostics port for fast plug and play install.
Plug and Play install
Quick plug and play install with zero cutting required. All power, ground, and data points come directly from the diagnostics port connector.
Boost/Vacuum Display
High resolution boost/vacuum via diag port for FAST install. Optionally read boost via boost tap (not included).
Multiple Gauge Displays
Boost/Vac, Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Speed, RPM with Shift-light, Battery voltage and more!
Peak Recall & Run Record
Recall the peak value from any mode, or record and playback 15 seconds of data from the current mode. Temperature peaks recorded in the background.
Universal Aux Inputs
Includes additional inputs to optionally connect any 0-5v sensor with universal settings for display ranges and bargraph displays from -999 and 9999 max values.
On the Fly Configuration Menu
Lockout/Display off mode, English(PSI, F, MPH) or Metric(BAR, C, KPH) selection, Adjustable boost display resolution, Ambient Calibration for boost sensor and more!
Email or PM for pricing!
(gauge only)
*Pre-installed in OEM vent (+$80.00)
To order:
Please PM or Email Frank@KMDTuning
