Danny Boy1
anyone have experience doing this? I can access the page on my netgear router its just that every online article says different port numbers :iono:
sweet ill try these. now when I type them in do I open and end them on the same number? like the first one, do I type 88 for the start and 88 at the end point. or do I open a range through it 87 then 89
If you have the option of upnp you should enable that on your router. Saves you time and effort going through the port numbers.
Are you getting an error of moderate or strict nat?
Sounds like a dhcp reservation problem. You should have dhcp enabled with a large enough pool (254 for instance) that can dynamically assign your xbox a new rfc1918 address so as to not overlap any statically assigned problems.
Punch these through.
Xbox LIVE requires the following ports to be open:
Port 88 (UDP)
Port 3074 (UDP and TCP)
Port 53 (UDP and TCP)
Port 80 (TCP)
