Cuervo
Ok so first, I'm sorry I didn't check to see if this thread is started already. But I freaked out so I wanted to post something ASAP since most you you know more about this than I do. Here's the scoop:
So I was driving to work in the after noon, everything was fine. Turbo was working, if I needed to speed up, I felt it engage and I speed up just like normal. I get to work, park my car, leave it til my shifts my done. Come back, turn it on, let it warm up a little just like always, and drive off.
About 12-14 miles after I started driving, I needed to use the turbo to speed up, well it didn't engage. I'm not sure why. No lights on he dash are on. The only thing that turned on was a snowflake symbol letting me know it was under 40 degrees (F) outside. My initial thought was, maybe the sensor won't allow the turbo To engage if is cold. But I have no idea.
Like I said, it was fine before, everything is stock, 38,xxx miles, just got an oil change about 1200 miles ago with 5w40. I haven't touched a thing but idk what's going on?
Any help will be appreciated, but I'm not going to go out and check right now for anything, just because it's too dark out. I'll try anything on the morning. I'll test drive it then too to see if the cold air was the problem.
(Sorry if this is the wrong place to post this, i used best judgement)
