this may be a stupid question, but why turn it off?
Just a guess, but by the nature of the way it works, vibration reduction or image stabilization can probably actually cause the reverse when used in combination with a tripod, sense I doubt the lens knows you aren't using the camera handheld. So the mechanism is active while on the tripod, causing ever so slight vibration in the camera.
EDIT:
This is straight from Nikon's Knowledge Base
When using my VR lens on a tripod, do I keep the "VR" On or Off?
Answer
The Vibration Reduction technology built into some Nikon lenses or the COOLPIX 8800 can reduce or eliminate vibration during shooting. When the camera is on a tripod there will be very little (if any) movement so the question arises if VR should be used or not.
There are two techniques when using a camera/lens mounted on a tripod; keeping the pan/tilt head loose or fluid (when panning or moving with a subject) and keeping the pan/tilt head locked down and rigid while using a cable release (time exposures or for the new HDR techniques).
With the following lenses/cameras VR should be "Off" when the camera is mounted on a tripod and the pan/tilt head is locked down and using a cable release:
105mm f/2.8G ED-IF AF-S VR Micro Nikkor
18-200mm f3.5-5.6 ED-IF AF-S VR DX Zoom-Nikkor
24-120mm f3.5-5.6G ED-IF AF-S VR Zoom-Nikkor
70-200mm f2.8G ED-IF AF-S VR Zoom-Nikkor
80-400mm f4.5-5.6D ED VR AF Zoom-Nikkor
70-300mm f4.5-5.6G IF-ED AF-S VR Zoom-Nikkor
Coolpix 8800
With the following lenses/cameras VR should be "On" when the camera is mounted on a tripod and the pan/tilt head is loose (fluid) while using the cameras shutter release button:
Coolpix 8800
Nikon VR technology in the following lenses can detect minute vibrations that emanate from tripod legs. With the following lenses VR can be "On" when the camera is mounted on a tripod for either technique:
200-400mm f4G ED-IF AF-S VR Zoom-Nikkor
200mm f2G ED-IF AF-S VR Nikkor
300mm f2.8G ED-IF AF-S VR Nikkor
For all lenses VR should be "On" when the camera/lens is used on a monopod
I'm assuming the last 3 lenses have the best technology and don't effect the camera enough to matter, probably due to their weight and length.
