Velociraptor Thrust
Could you print a TOP or TB pipe? Are the plastics, abs or PVC I think, strong enough to withstand the boost pressures?
Been on the forum for 2 years and have never seen anything like this. Awesome!
Got it! This was after the engine was running for about 30 min, with 10 min of city driving. I've circled where on the pipe I was getting the reading. Ok never mind photo bucket isn't cooperating today... looks close and you can see the laser. This is with a neuspeed FMIC BTW.
Hmm, it's possible, though I'm not super sure what the strength of ABS or PLA are compared to the material used currently...
Pre-intercooler boost pressure temps can reach 350+ degrees F. ABS has a service limit of about 200 degrees. I would never use PLA in an automotive environment for anything other than a test fit.
Almost all OE under hood plastic parts are glass filled Nylon 6/6. Some of which are rated for 400+ degrees.
If I was going to 3D print an underhood part for sustained use I'd probably have it made out of Ultem on a Fortus machine.
but for something simpler with minimum strength/heat requirements it would likely be OK. Hence why I'm sticking to aesthetic pieces for now lol
PLA will likely soften and deform in the summer heat. Glass transition happens at about 140. Since it's only cosmetic it won't hurt to find out but once you have your design finalized you might want to consider getting it from Shapeways in their strong and flexible material. It's Nylon and can take quite a bit of heat. Also that way everyone else could buy it .
VS, what do you think of the makerbots? The reviews I have read are very pro or con. Not really in-between.
Nice! I'd like one that looks like a Golf Ball. You could work on a set of DSG paddles, too.
This is pretty cool. Have you considered other projects for the car?
I have this crazy idea for doing a headunit delete and installing nexus 7 tablet in my car. I'm doing it no matter what but would love set it up as a as a easily removable install.
I'm thinking I might try to model out the scosche dash kit for the GTI. Then take a (hopefully) proven model for the nexus 7's case and merge the models together to create a dash kit that has perfect fitment and lets my tablet rest flush in the dash.
I have 0 experience with 3D modelling but I'm not going to let that stop me. I'm planning on testing out sending pictures of the dash kit to the Autodesk 123D Catch service and get a model from them. I'd love to hear from you if you think this is feasible or even worth it.
We live in such an awesome world where anything we could possibly want is a button click a way, but someone has to create the model first.
