Sounds like this: http://www.youtube.com/watch?v=dQw4w9WgXcQ
point of this...
point of this...
Humor.
Maybe five years ago I guess. Still funny up in Canada?
It never gets old no matter where you are.
When did reading comprehension get old in the US?
"It sounds like a failing idler bearing but the sound is coming from the right side of the motor. If it's failing you will be able to hear it fairly easily. Although this is not a very technical explanation, it does sound like some sort of animal is in the engine."
Haven't you checked the stats? Last place in pretty much everything. Pretty dumb down here.
Was pretty much asking for more clarification. I am not sure if I am trying to listen for a grizzly bear, or a cricket. Engine sounds like shit normally. Not sure how much worse it sounds with a failing pump. Also have no idea what a failing idler bearing sounds like.
Can you do a your mom joke for a follow up? I hear those are just starting to catch on.
Sounds to me like you probably shouldn't be trying to diagnose your own car.
If you're so unsure why did you even think your pump was failing?
I'd put my money on its fine.
And here's a good one for you: Your mom is like a hardware store, 5 cents a bolt, 10 cents a screw.
