[FONT="]Hi guys, [/FONT][FONT="][/FONT]
[FONT="]I just wanted to clear something up about the DV+ spring being discussed at the moment. We have not changed anything in the DV+ kit or made any revisions to the production spring.[/FONT][FONT="][/FONT]
[FONT="] [/FONT][FONT="][/FONT]
[FONT="]We are however doing some testing and HYDE16 is helping us out with this at the moment, but testing and results at this point are not conclusive. [/FONT][FONT="][/FONT]
[FONT="]The current DV+ spring (which hasn’t changed and isn't about to) provides the best throttle response – we spent a lot of time and testing on this spring initially during the DV+ development to confirm. Optimum throttle response however can sometimes lead to low RPM flutter (usually more common on tuned/modded K04 engines) which, whilst not detrimental to the engine or turbo, is sometimes deemed annoying and undesirable.[/FONT][FONT="][/FONT]
[FONT="]The current DV+ certainly has the solution – if the flutter noise is an issue, simply removing the main spring (the short fat one, not the long, skinny one) will make the DV+ open and close the same way as the factory valve, which prevents the flutter. However, this forfeits the throttle response benefit (NOT the boost-holding ability though, that is independent of the spring).[/FONT][FONT="][/FONT]
[FONT="]So, can you get rid of the flutter AND keep the throttle response? [/FONT][FONT="][/FONT]
[FONT="]Well, this is a significant challenge, and one that may or may not be possible, because what the diverter has to do to improve throttle response (which is to only open when required, only as far as required, and only for as long as required, no more) is completely different to what is required to eliminate low RPM flutter (which is to open fully, and only close when the throttle is re-opened). It’s a bit like fitting a huge turbo, and then wanting it to spool up like the stock turbo – some objectives can’t always co-exist.[/FONT][FONT="][/FONT]
[FONT="]What we are investigating is if it’s possible with the spring to have a suitable compromise between maximum response and minimum flutter. We know through testing done on other modified cars this is not always possible, especially with larger turbos and tunes that attempt to bring boost on aggressively at low RPM and small throttle openings.[/FONT][FONT="][/FONT]
[FONT="]Anyway, we will continue to test and if a compromise is possible we’ll certainly make sure to let you guys know![/FONT][FONT="][/FONT]
[FONT="]In the meantime, if low RPM flutter really does annoy you enough, try taking the main spring out and see if it satisfies your requirements.[/FONT][FONT="][/FONT]
