But the SHS, ST's, V1, V2, V3's.....they "should" be all the same height wise....it's pretty much all the same design across the board in the front struts & rear perch setup....just the ST's aren't stainless as opposed to the rest.
And then there is no difference in the V1 & ST dampening. SHS supposedly has different dampening and/or softer springs though.
And then the V2's have rebound adjustment.
And then the V3's have full adjustment.
So they should all be identical in the end though
But I hope that these are truly softer than the ST's. ST's weren't bad, but were kinda stiff (on my CC). In comparison, the Koni's were softer for sure.
I am surprised you are rubbing with those wheel specs. I'm at about 24.2F/24.4R FTG and I have zero rubbing. I wouldn't have thought the A3 fender wells to be that much different?
Bah I got my alignment done at a shop that isn't really familiar with VWs or lowered cars, and they took out too much camber in the rear...now I am rubbing bad in the rear.
Super annoying....I should have just waited to get in to the place that knows what they are doing with these cars.
Pretty sure there may be some differences in height in the KW's, I'd check the HPA or other KW sites again to make sure.
i like it better now than before. That ass up... :wub:
By any chance did you try these all the way down? how low is it?
