mattley crue1
Whatever you choose you will be happy... If you want something compliant... Go with something adjustable so you can mess with it.
People run konis pretty low and are happy with them I think you will be happy with them and for less then a g they are cheap plus you get some rebound variations
x3...I think you'll be happy with the Koni's
Plus you'll save money with them too & have the adjustability
V1s. they are superb. and yes, you can go as low as 24-24.2 ish ftg with the V1s.
If V1s are valved like STs then no. Get the Konis.
Driving on anything other than perfectly smooth roads was an absolute headache. Well, at that height....anything is pretty much a headache.
Most people have the rears set to full stiff?
They are a really good price. Hard to argue with. Sorry but what's rebound variation? Is that just saying i can adjust how mcuh bounce ill get my stiffening or softening the damping?
Rebound will stiffen it or soften...
A good suspension shouldn't bounce...
I have the ksports, full stiff in the back half way up front... I need to stiffen the front though.
It's a really stiff set up but no bounce, actually really refined feeling.
Most people that do that want it geared for better handling though.
If you want a nice ride though....you only need a 1/2 turn from full soft to keep it "buttery" like everyone describes
Ask Jason3d.....he tried the different settings and wanted a smoother/softer ride and ended up sticking with the softer setting in the rear.
The fronts are easy to adjust though and you can change whenever you want
Yes but if you want to get technical The adjustments on koni aren't linear they significantly ramp up the closer you get to full stiff. Also koni suggests using the rebound adjustment for deterioration as the shocks wear.
That's something I'll have to play with though eh. What's rebound adjustment? Is that the same as damping adjustment? I don't know much.
So the more stiff, the more my bum will die?
I'm in the same boat as you, but I'm leaning toward the Konis, shame Concept 1 doesn't carry them.
This is an interesting read
http://farnorthracing.com/autocross_secrets.html
The short of it is. There is compression (car goes down or suspension gets compressed) and rebound (car goes up or suspension decompresses). The job of the shock is to control those forces rebound adjustment allows you to adjust the rate or force need to decompress the shock. Too much and the tire won't stay in contact with the road too little and it will be bouncy.
Sort of... There is a difference between firm and harsh... Low quality suspension when set to firm is a bit harsh. Higher quality will be firm but more refined.
Everyone has a difference in opinion though. I would go to some GTGs, steal people cars with different suspension set ups and go joy ride in them....
Err maybe ask for a ride....
The Koni Coils will pop, crash because they have to be too low, and wander all over the road. Terrible coils. Killed Koni for me...
I can probably get you a good deal on SS if you want since my buddy upgraded to DG/B8. Personally I'd sell the Koni's and get B8s with your spring of choice. If you like low, then VWR IMO.
My buddy hated the SS since he had stock dampers. They were really low and rode poorly. Looking under the car at the back the progressive coils looked bound to me. I'm not a fan of progressive coils after the H&R, and the Konis... Never had a good experience with them.
About the Konis, how bad would it bother you to hear metallic pings when turning into your driveway, or going over speed bumps? They are designed to be so low, and if you go above that then the noises they make get worse, especially as the springs sag, and sag, and sag. It's up to you. You might have to try it to find out if they are for you. Also, they do not hold a straight line on the freeway so be ready to make constant corrections.
Really couldn't say... Definitely the Koni springs are trash. I'm surprised there hasn't been a class-action, or recall on them.
The dampers are probably fine, but after spending $1300 for coils and some install parts, plus installation, to have to go through that is unacceptable. IMO A visual comparison between Koni and Bilstein also shows a general build quality superiority with the Bilsteins. Pull up pics of both and look at them (welds, paint, etc.). :iono:
Trust me if I thought the coil overs were livable, I wouldn't have sold them and switched suspensions. I'm a bit older and want a suspension that I don't have to worry about, or keep changing. It's a lot of time, effort, and money to switch out.
