I put in the seat and it was way too close and too high with standard bolt in parts. With redrilling the side plates and slider and reducing the cushion thickness, I now sit lower and have almost near factory range on the seat position.
After this photo was taken I redid the harness strapping and added shaft collars to the harness to hold the belts in place.
I can still use my stock seat belt, and am working on turning off the airbag light with a resistor for the airbag and seat position sensor.
Also changed out my front Textar pads / rotors. The pads were running close to the wear sensors with about 3 mm left after 2 HPDE's and a total of 11,000 miles. I changed to Hawk HP pads and Zimmerman Z-Coat rotors. Used the Motive Power Bleeder which made the swap really easy.
