Eat_My_Shorts
Have not even looked, been getting sick so trying to keep low as much as I can now.
Just finished this up, both DRL LEDs work, rear fog works, just need to get my reverse light working. At least I can pass my MOT inspection now and get my road tax covered by uncle sam.
You guys still in the UK? I'm finally at Mildenhall. Still waiting for my R to arrive. Aside from reaiming the headlights, I believe it should be good to go. Did you guys run into any surprises trying to get MOT/SVA done?
Do you have xenon lights? If so I would vagcom it to adjust them.
What mods do you have done? I know for my the only issue I had was my exhaust. It was caused by my TBE. I found another tester that let me stuff my exhaust to get a reading that would pass. Other than that it passed with flying colors.
Good thing I brought my cable. Yes on the xenon. You mean enable the travel mode or is there some other VAGCOM adjustment? I did play with the travel mode setting and they were moving around. All I have is a Borla catback so that should be fine I'm assuming. Rear fog on right side works with indication inside, it had the side turn signals in the mirrors, and up front I enabled the white city parking lights. Anything else I might be missing?
Is your cable OEM? Direct from rosstech? If so hit them up, send them a scan of your car. They will tell you what to change and what the value should be.
They have 2 options, the first is just adjust, the other is to have the option to change under setting on the display. I tried the 2nd one, but when I went to get tested was told it was not aimed right still. So I did the 1st and it passed.
You should be good with the exhaust, I have a TBE and it was the DP that got me. Everything else sounds good, all I had to do was the rear fog, and adjust headlights.
If you find yourself my way let me know, I'm very active with a local car club with a group of great guys.
