whitebeastMKV
I just installed this clutch kit a couple of days ago, and so far I really am impressed and like it; I like the feel of the clutch pedal and also got used to it grabbing way lower than the stock CRAP clutch vw put in there from factory.
One thing my dad noticed when we did the install was that the RSR pressure plate actually has a smaller area where it clamps onto the clutch disk compared to the stock one. So if you measure the thickness of the RSR one compared to stock is deffenately smaller also as seen by pictures where I marked them A and B.
RSR pressure plate (marked as B)
Stock pressure plate (marked as A)
RSR clutch disk which has same dimensions as STOCK ( Marked as C)
So to me what that means is that the RSR pressure plate will not cover the whole the clutch disk on the pressure plate side but it does so on the FLYWHEEL side because the RSR clutch disk has the same overall diameter as the stock flywheel and stock clutch.
So far everything is good, but i don’t know what is gonna happen over time as NOT the WHOLE surface of the clutch disk (on the pressure plate side) will wear out the same as it will on the FLYWHEEL side; I guess only time will.
But I just wanted to point this out and I’m sure the guys at HS tuning that put this clutch kit together know about this, tested it and everything is OK. But was just wondering if anyone else noticed this when doing the install???
