sticksabuser
RSR clutch is for sale at hstuning FYI
Sent from my Nexus 5 using Tapatalk
maybe hyde can comment on here, but i'm having vibration when revving up and it's only in the lower rpms. I had rsr clutch, low miles oem dmfw, and 034 trans and motor mounts installed all at the same time. oh and LSD. could the mount be whats causing the vibration?
https://www.golfmk6.com/forums/index.php?threads/build-your-own-rsr-clutch-kit-parts-list.273966/sorry to bring this up from the dead...
i know this is a mk6 gti forum, i sold my 6 gti a while back and now that i have an MK6 R i need to upgrade the clutch on it and was wondering i anyone can
provide the needed part #'s and links where to get the ttr-s pressure plate, euro tdi disk as well as all metal trow out bearing??
i my prev mk6 gti i had bought the rsr from HS tuning, but i know a lot of people pieced their kit together using the same parts for a lot cheaper.
thx in advance.
FCP euro has what it looks to be teh same clutch disk....
Audi Clutch Disc - Sachs 03G141031P
but it the part # ends in P instead as the link you posted which it ends in T
is this the same disk and will it perform the same??? here's the link form FCP euro (from pictures it seems to look the same)
https://www.fcpeuro.com/products/audi-vw-clutch-disc-sachs-03g141031p#description
thanks
The last letter in the part number is usually the revision version iIrc... I think if the p/n itself is the same it should be good?so nobody knows if this clutch disk from FCP euro that ends in P is the same as the one that the original person strarted this tread in which that disk part # ended in T
they both seem to look the same in pictures
