KurtP1
Organic is overrated
Then eat whatever you want, brah.
I would never purchase organic dairy - its absolutely disgusting if you knew the repercussions. If people want dairy but don't want the additives, get rBST free dairy.
Any of you guys prefer training before a work day as opposed to after? My current routine calls for me to be up at 3:45 and I have noticed taking pre workout at this hour severely inhibits it's effects.
I do both, and 2-3x a week i do a third right before bed, so there is a work out every 8hr interval of the day. I generally use the pre-workout during the mid-day workout (which is the hardest/most intense) to match the body's timing cycle.
It has to do with your REM cycle/circadian rhythm. If you are getting up then rolling right into a prework out supp/work out your body isn't ready for the "jump start" that preworkout supp is going to give - especially if its caffeinated.
In a nutshell, your body isn't fully "woken up", and no amount of supplement added can accelerate you along your circadian rhythm....you can be "more awake" at that time, but not "further along" the rhythm, if you think about it as a sin wave.
You can re-arrange your circadian rhythm somewhat by changing your sleep patterns, so things like zinc and melatonin can help. Going to bed earlier and getting the 8-10hrs sleep before your 3:45 wake up will help also, but you obviously have to get your cycle shifted to the left far enough that you are "tired" at 7-8 at night. Do some research on the body's sleep cycle, circadian rhythm, and hormone production cycle and you will start to see the patterns of when you are "most awake", and you can start to shift/adjust accordingly...either your sleep or your supplementation/workout schedule.
4 AM heavy deadlift sessions assure an 8:30 PM baby seep mode; interestingly enough, ZMA gives me horrible insomnia whereas Melatonin puts me right to bed. I feel that 7-8 hrs is my sweet spot and I can function and be effective at work and lifting with that combination. Might re-up on my clen to get me stimmed out when I lift early. I usually spend 1.5 hours training but I now have to cut back to 1 hr and 10 minutes on the weekdays but this allows me to go hard on the weekends after recharging friday and deters me from partying on Fridays. I've also noticed a restriction of peripheral calories since getting on the grind which is working wonders for my abs. I usually sit around 7% but I strongly feel I will be able to get around 5% out of my body with this change; I love it especially since I do very little to zero cardio. Clen is a hell of a drug
Yeah its an over the counter sleep aid. It more or less is a non habit forming supplement that puts you into auto-pilot and helps you wind down even more when you are sleepy. The only possible side effect is nightmares but usually I just get really vivid dreams.
I wanna try some melatonin... Is it totally safe?
Do you have any links to studies that prove this?
