Better seal? Its usues the OE coupling. If it leaks its not because of awe's design.
Did he test the AWE unit or the Neuspeed?
THAT is an AWE tuning pipe, so the review is completely misleading. Neuspeed has a much thicker aluminum rim on it.
well thats better since you removed that AWE box in the pic then. Glad you got the better pipe, which is indeed the Neuspeed.
Wow! Nearly 10hp on the dyno!? Impressive and surprising! I didn't think there was much left to do beyond a normal stage 2 setup with supporting mods. I have a Carbonio intake, S3 IC, downpipe, and stage 2 file. I kind of figured that was tops for the OEM turbo. Hmmmm... more ponies? Dammit!
Thank you very much for the quantitative test as opposed to the butt dyno. Back to back same day dyno results for the win! :thumbsup:
